Home Forum Ask A Member BEST RECOIL ROPE MATERIAL
  • #1025
    hugh
      I HAVE A FRIEND THAT I GOT INTO LIKING AND RUNNING 50’S VINTAGE OMC’S. HE IS NOW UP TO 7 OUTBOARDS. I DO ALL HIS MOTOR WORK FOR HIM.
      HE HAS A ’56 15 HP FASTWIN HE USES A LOT. IT KEEPS BREAKING THE PULL ROPE. HE IS A BIG GUY WITH LONG ARMS SO I MAKE SURE THE ROPE IS AS LONG AS WILL FIT, HOWEVER, THE ROPE BREAKS WHERE IT IS TIED. I HAVE DEBURRED THE AREA WHERE IT ATT TO THE RECOIL. NYLON ROPE IS NOT GOOD I HAVE FOUND. IS THERE A REALLY GOOD MATERIAL FOR THIS?
      HE NEVER BREAKS THE LOANER UNIT I PUT ON TO KEEP HIM GOING
      #12770
      dave-bernard
        I use mercury rope on my motors no that expensive .
        #12774
        burt
          Braided cotton rope sold by boating concerns…and teach Rope-zilla how to pull one over, it’s not the strength it’s the stroke.
          #12780
          crosbyman
            try one or two strips of shrink tubing where it rubs
            #12782
            joecb
              Be aware that not all braded nylon rope is created equal. Most of the stuff that you find in the "box" stores is soft and loosely woven. The good stuff is tightly braded, dense and rather stiff. What kind are you using?
              #12788
              twinrudes
                I use Stens True Blue #7 rope, so far so good.
                #12789
                Steve A W
                  US Member - 2 Years
                  I get mine from a small engine repair shop.
                  Haven’t had any trouble.
                  Steve A W
                  Member of the MOB chapter.
                  I live in Northwest Indiana
                  #12814
                  donsmarine
                    sierra 18-4911, 18-4913, 18-4914, numbers for rolls of pull cord.
                    #12817
                    aquasonic
                      quote Steve A W:
                      Steve A W
                      I’ll second that… Power equipment cord is tough and made for the purpose. The power equipment shop I go to has four different diameters, so I just bring in a piece to match up, and I usually buy 20′ or more. It is inexpensive too.
                      #12831
                      hugh
                        O K, I got a lot of information here. I have just been using hardware store stuff. I ordered a couple different ropes recommended at the proper diameter for stock size 7/32. I was thinking of using something to pad next to the knot too. Shrink wrap may help. I am going to mention to my friend about proper pull starting. He probably has a 6’6" reach and hitting the end of the rope is not good.
                        Should be able to get him fixed up and learned a bit about recoils for myself.
                        Thanks 😉
