Home › Forum › Ask A Member › Best Way to Unseize an Engine
Viewing 10 posts - 11 through 20 (of 35 total)
  • #15802
      Do Yourself a favor and skip the impact gun.
      If the engine doesn’t break free, You run the risk of over tightening The flywheel and ruining it.
      Use a strap wrench on the flywheel instead.
      Steve A W
      #15803
      aquasonic
        quote crosbyman:
        https://www.youtube.com/watch?v=Q-Gq8i73gYs
        timely video for my 9622a stuck beauty πŸ™‚
        If your engine is seized up badly, this doesn’t work. I tried this product and technique after soaking the pistons in ‘you name it’ for about six months.
        The end result was a broken crankshaft. I will never tighten a flywheel nut with an impact wrench again.
        I was lucky to find a good powerhead replacement.
        Improvise-Adapt-Overcome
        #15804
          πŸ˜₯ ok
          #15805
          aquasonic
            quote aquasonic:
            quote crosbyman:
            Just to expand on this. I am fairly certain that my seized motor was used in saltwater and had been tipped so that saltwater ran into the exhaust ports and into the pistons by an owner that didn’t know any better. Then it was laid down on a garage floor without being run in a fresh water tank and not fogged. When I removed the cylinder head there was lots of white aluminum oxide.
            Basically, everything had been done wrong from a storage point of view.
            If your powerhead is just weather seized from sitting, then the chances are very good for getting it unseized.
            I just don’t want people to think that the product from the video is some kind of miracle because I can tell you that it is not!
            #15817
              pretty certain it is totally 100% freshwater animal so i will just keep soaking ad give it 30 days if still stuck i will pull the head and starting tapping the cyl. with a peg and rubber hammer
              #15819
              legendre
                quote Steve A W:
                Heh, wow! Yeah, that is definitely in the "DO NOT RECOMMEND" category.
                I mean, a couple +quick+ shots from the impact, to give it a jolt.. maybe. But rapping on it while the pistons remain stuck is just begging to twist the crank, crack the flywheel, ruin the thread, and so on.
                There’s a reason you can almost always R&R a flywheel bolt using an impact tool, without the aid of a strap wrench or flywheel holder. The inertia of the flywheel backed by the compression of the engine ensures that the whole crank essentially sits still while the flywheel bolt is being torqued.
                #15824
                  If you don’t have a press, to get stuck pistons out, I have boiled them in a crock pot with anti freeze. Same idea as Lloyd had.
                  #15840
                  legendre
                    quote Chris_P:
                    Oh boy.. your wife must love you! πŸ˜†
                    #15845
                    thepetrolist
                      quote legendre:
                      quote Chris_P:
                      My GF wasn’t too happy when I heat treated an exhaust/intake manifold in our kitchen owen after painting it with some heat paint that needed treatment to harden..
                      Nowadays she just sighs and pretends not to notice. πŸ˜† 😯
                      #15849
                        I share Scott’s opinion, any motor worth spending the time to free it up should be torn down
                        cleaned of any corrosion & or rust that may have caused it to be stuck in the first place. I personally would stay clear of the impact myself, light tugs on a strap wrench is a much safer approach.
                        Respectfully
                        Brook N.
