Home › Forum › Ask A Member › Boat Explosion in Bahamas
- This topic has 9 replies, 9 voices, and was last updated 5 years, 9 months ago by kerry.
July 2, 2018 at 1:14 am #10438
What do you think happened? Yamaha Outboards not inboard!
https://www.msn.com/en-us/news/video/on … spartandhp
July 2, 2018 at 1:47 am #78864Don’t know, that’s for sure. But with gasoline on board, all it takes is fumes & a spark. Electrical issue + venting issues?
July 2, 2018 at 1:57 am #78866‘No medical facilities nearby and no first aid kit on board. It was a nightmare’.
July 2, 2018 at 2:23 am #78872Mostly likely gas vapor in bilge or possibly propane?
July 2, 2018 at 9:47 am #78875What ever it is, it won’t be determined to be Yamaha’s fault. We service literally hundreds of those bigger motors and nothing like that has even come close. Whatever it was, it will probably be deemed to be a product of electrical+gasoline+improper service and/or maintenance. It could also be the result of a low-amperage short. Corrosion, particularly in high salt, hot humid areas like the Bahamas (or Florida) can cause partial shorts to ground. Or just a really high resistance in a circuit that should have very little. This will often cause heat, sometimes lots of it, without ever blowing a breaker. If this happens near a fuel source, it is bad news. Corrosion has nothing but time on its hands, while the tour operators are under pressure to keep the boat in service, no matter what, due to their schedules.
I was just on a couple of boats like that down there, this February. Even if a reputable cruise line like ours contracts locals to provide transportation, that transportation can often be very, very sketchy.
Even though it won’t be Yamaha’s fault, I am still glad that there weren’t Mercs on that boat. It makes the companies look bad, even though they have nothing to do with the problem.
July 2, 2018 at 12:25 pm #78882Fire is nowhere near those motors. Something unrelated to the motors happened.
July 2, 2018 at 12:44 pm #78883One other thing: while gas vapors quite likely played a part in the ignition, a lot of what you see burning there is fiberglass. It’s a chemical reaction thing…once it gets going, there’s very little stopping it.
July 2, 2018 at 1:21 pm #78885Lawsuits down the road. Death, double amputation , burns, disfigurement….sad.
July 2, 2018 at 5:33 pm #78900As Billw noted, could very well be related to bad wiring. I had a near disaster on my last boat caused by a corroded wiring connection. Only found it when electronics started acting up and by that time the main hot lead to the dash was starting to melt through the insulation. Could have turned out just like that Bahamas boat with my fuel tank mounted on the deck right under the console.
"Every time you remove a broken or seized bolt an angel gets his wings."July 2, 2018 at 11:41 pm #78918Or an errant cigarette?
