Home Forum Ask A Member Boat Tach on car
  • #9036
    mike-stroz
      I know this is a pretty unusual question, but I’ve got a 1950’s OMC accessory tach from the 50’s that’s just about the right look I want for my 1971 Mustang and I was wondering if it’s possible to use it on there. I’m sure it’s meant for a 2 cyl motor of some kind, and on the tag it says that one wire goes to ground and the other goes to the "non regulated output side of alternator". I can post some pictures if that helps
      #69874
        US Member - 2 Years
        A belt driven instrument will not be accurate, Remember early Vettes used a drive from the genny for RPM? Two to one with 2 or 4 stroke,
        #69875
        mike-stroz
          I know it probably won’t be too accurate, it’s mainly for the look and to get an idea of the rpm on the highway. I’m just wondering if I can get it close enough
          #69876
          58fourfifty
            Hook up a dwell/tach to your Mustang so it reads the correct rpm, then jump some wires from your boat tach and compare readings.
            simple!
            #69878
              You obviously have a tach that receives an AC signal from the flywheel alternator. It counts those AC peaks. It certainly isn’t going to give proper readings on your belt driven alternator, which runs at way higher RPM than the engine.
              #69886
              mike-stroz
                I’ll definitely test it out using another tach, but if it’s meant to be put on an outboard with the alternator connected to the flywheel, I would think the pulley ratio would be fairly similar. On a car, the alternator pulley isn’t that much smaller than the drive pulley on the end of the crankshaft. I’m thinking the outboard might spin the alternator faster because of the pulley or gear ratio
                #69889
                  Beside all that, how many poles does the car alternator have?
                  #69892
                  mike-stroz
                    I might be wrong, but I was under the impression that these tachs took a signal from just one pole so it doesn’t matter how many, it’ll just get a signal once every rotation
                    #69893
                    dave-bernard
                      yes 1 pole per revolution but on a car the alt turns more than 1 turn per rev with the belt.
                      #69896
                        My neighbor at Houghton Lake was a test engineer for Oldsmobile. One of his jobs was to calibrate the instruments. Using a "fifth wheel" he would drive at a certain speed and then mark on a blank face plate where the indicator needle was at that speed. I have to say, some of the best (fastest) cars they made never saw the light of day. That could be a way to calibrate your tack if the face plate is not too hard to remove. . . 😆
