Home Forum Ask A Member Brazing Skegs
  • #8756
      Need some sage advise from you Aluminum Brazing experts.
      I brazed one side of a new skeg onto my Johnson Model 100.
      Thought I’d ask for some tips before I proceeded to the
      other side, as when I practiced on a scrap piece of the same
      skeg material, I was able to fill in the "V" notch on the first
      side okay. I waited long enough until the weld puddle cooled,
      turned it over, and as I was welding the other side, I melted
      the weld out of the first side. 😮
      I probably should have practiced more before the actual skeg,
      but I didn’t.
      I’m using HTS-2000 rod.
      I placed a wet rag in the gear case and bolted the cover on,
      thinking that would help from warping the gear case.
      Not sure if it worked or not, but I had steam coming out
      the top of the gear case before I was done!
      I could not find a good way to clamp the two dis-similar thickness pieces together,
      and the clamps were in the way anyhow, so I clamped each piece separate
      to angle iron and butted them together.
      Hard to see the weld in the photo, but if I could get the second side as
      good as the first, I’d be happy.
      If anyone has tips on not melting the first weld out
      while welding the other side of the "V", I’d be most happy.
      Thanks!
      b-dittmar
        I am planning a fishing trip to Red lake on the 5th would you like me to stop by and show you how to weld it?
        #68007
          Ben, I guess I’m in no hurry, so if it’s not too far out of your way,
          I’d like to see how you do it.
          I’ll PM you.
          Thanks!
            Put a piece of steel on one side and let it flow through.
            You need to get enough material in there the first time
            as there is no going back to just add a little as you have
            learned. Then remove the excess.
            #68023
              Tubs, I watched some Youtube videos of similar methods
              as you suggest. They used a backing plate to fix props,
              and make new "ears" or bolted flanges on items, etc.
              Perhaps if one made a tight enough dam out of tin
              on the back side, you’d end with enough material
              to machine level when done brazing.
              Ben may swing by neck of the woods and show
              me his method.
              Thanks for the idea. I have more with broken
              skegs to practice on once I know what I’m doing!
                I have got a skeg on the to do list also.
                Smaller than yours though.
                #68032
                kees
                  International Member
                  Small and thin material you can try to braze but
                  a skeg of a bit thicker aluminum … my way is ;
                  … MIG welding …
                  you melt and mix both materials together to form a strong new mixture,
                  the use of argon gas prevents corrosion during the process
                  it is the way to built complete constructions and big ships
                  good luck
                  #68037
                    This skeg will be mostly for looks.
                    Assuming this Johnson runs again,
                    I don’t think the speed and thrust of
                    a mighty 1.7 hp Model 100 will strain the
                    skeg too much. 😆 ………
                    but I’d hate to have it fall off while hanging
                    on the rack!
                      Actually tried to weld that prop first.
                      Too contaminated. Was just blowing
                      more of it off. Its on a Mercury KF-7
                      Super 10. Ran 55 gallons of gas through
                      the motor before I gave it to a good
                      friend of mine. Had fun with the colors
                      and getting it running again but its too
                      modern for me.
                      He ran it the rest of the summer. To be
                      honest I didn’t expect it to hold up either
                      and brought a spare prop but I never
                      needed it. Why I plan to use it on the
                      skeg repair. Want to get a better
                      understand of how to use this stuff and
                      its limitations.
