Home › Forum › Ask A Member › Buzz Box Wiring
  • #9176
    slim60
      I am building a buzz box to run my ’22 Evinrude rbm that has a dead coil. These are the coils I bought. Would someone please post a wiring schematic and suggestions on a battery.
      RICHARD A. WHITE
        Frequently the condenser is at issue, How did you check the coil?
        classicomctools@gmail.com
        #70822
        PM T2
          Hope this helps
          best,
          PM T2
          #70823
            An article on using Model T coils for hit and miss engines here……
            https://www.smokstak.com/articles/buzz_coil.html
            They use to sell wire clips you could solder on the Model T coil
            buttons, then attach your wiring to those, instead of soldering
            the wire directly. Seems like they were call Farenholz clips or something
            similar.
                Phil, Yes, those are the clips.
                At least I got the first letter correct!
                  I just soldered some brass screws on mine.
                  This is the battery I use. They are cheap,
                  seem to last a long time, and are sealed.
                  Some searching may find them even
                  cheaper.
                  https://www.ebay.com/itm/UPG-6V-4AH-Sea … SwoudW9YxJ
                  #70842
                  amuller
                    There is tons of info on these coils on Model T sites. How to set up and adjust the vibrating contacts and so on.
                    #70844
                      Bought a MK 25 & it had Honda mtrcycle coils, & a 12volt battery conn. Never checked the cap correctness,just went all stock mag,
                      #70848
                      slim60
                        Thank You All.
