Home › Forum › Ask A Member › bypass cover for a Johnson AD-10
- This topic has 19 replies, 8 voices, and was last updated 6 years, 8 months ago by
todd281.
June 17, 2019 at 9:02 pm #177409
I am working on this AD-10 outboard and have decided to change it, for now to a single line fuel system. I know that I can plug one of the holes in the check valve that is located in the reed plate, and use that port for the pulse to a fuel pump. However I was pondering if a bypass cover was made, for another motor, that would have the mounting holes to accept a fuel pump, and fit on this 7,5 HP. This would place the pump under the cowl neatly, and forgo using a extra pulse line. Anyone have a part #, or seen such a animal in captivity? Thanks
June 18, 2019 at 4:05 pm #177477First, I think you must plug one of the hole, but then remove the other check valve, so the pump will get both negative and positive pulses….
I don’t think there is another engine with a bypass cover that will fit the 7.5hp, unfortunately. You might take one of the covers to a welding shop and have them build up the surface of the outstide of the bypass cover so it is flush with the outer edge. This way, you can drill the two holes that are threaded for mounting, and you can drill a third hole directly through the cover for the pulse, then mount the small pump using the standard fuel pump gasket, just like on later style engines….June 18, 2019 at 6:35 pm #177486June 18, 2019 at 7:42 pm #177491yup i think i will take a stab at making a adapter , I bought a replacement powerhead so I will have 2 “extra” by-pass covers. I also have the ability to weld aluminum here in the shop so I will toy with it. I just thought maybe there was one OME . No seance in reinventing the wheel. Thanks and I’m off to the workbench..
June 18, 2019 at 7:47 pm #177492frankr, if you could tell me, were your adapters bolted over the bypass cover just put a hole in it , or did you remove the OME cover and bolt directly to the block?
June 18, 2019 at 7:54 pm #177495You leave the bypass cover on.
I like to fill the void with JB Weld, before installing a plate.
June 18, 2019 at 9:12 pm #177513June 19, 2019 at 12:22 am #177523Frank Robb used to sell an adaptor plate that hod holes that let you use longer bypass cover screws to fasten it to the motor. The plate was drilled and tapped the accept the standard pump. The only modification to the engine was the drill through the center hole so the pump could pick up the pulses. . .
June 19, 2019 at 1:30 am #177525sounds good thanks for all the info, I will make one as suggested that way if I ever get the pressure tank fixed, I can just remove this and put on the un-modified cover. Now if I could just find some match for “Holiday bronze” paint that’s not 20 bucks a spray can .
June 19, 2019 at 5:57 am #177527What is wrong with the pressure tank?
classicomctools@gmail.com -
