Home › Forum › Ask A Member › Cable and pulley steering – who to ?
- This topic has 6 replies, 4 voices, and was last updated 1 year, 9 months ago by
JOSEPH BRINCAT.
June 24, 2024 at 11:05 am #288573
I’m looking for a “how to” on installing a cable and pulley steering for a friend. I searched the usual suspects and find no good info. If he was closer, I would just go do hands on., but he is not nearby. Anyone have a link to a good video or other instructions?
June 24, 2024 at 11:48 am #288575June 24, 2024 at 12:01 pm #288576Not much good info out there. Everybody gets it wrong anyway. Especially the boat builders back in the day.
Ill be glad to share what i know so you can get it wrong in my way.. First tell me if any of the hardware is already installed. What kind of rope drum behind the steering wheel? Do both cables go down the same side of the boat or one cable down each side? Anything unusual about the boat or motor? Racing? Cables connector to front of the motor or to a tie bar on back of motor?June 24, 2024 at 12:09 pm #288578I had mine running both cables on the right side ..worked out pretty good with my home made steering box for Princecraft & Merc Classic years ago.
wonderfull engine… loved fuel but idled all day on 5 gal. great troller.
June 24, 2024 at 12:20 pm #288581Good video in post #2. I would deviate from that a smidge, as I don’t like his use of turnbuckles. But you do need tension on the springs, so how to do that?
I cut little wooden wedges that insert into the “extended” (i.e. under full tension) springs. This way I can cable everything up “hand taught”, which gets the cable as tight as I can. Then, when the cables are all clamped up, the wooden wedges are removed and the cables are tight.
June 24, 2024 at 12:37 pm #288582buckles are also for easy adjustments when the cables strech out
btw I have always used good clothes line steel cable..the one covered with clear vinyl …cheap and effective jmho
June 25, 2024 at 12:10 pm #288617Thanks guys for the info and crosbyman for the AU video. future reference and maybe help for another , a friend shared an informative chapter on “cable and drum” remote steering in the book “Cheap Outboards” by Max Wawrzyniak. I good book to have if you can find one.
