Home › Forum › Ask A Member › Calling all Coil Experts & Jack of all trades
- This topic has 14 replies, 6 voices, and was last updated 5 years ago by Buccaneer.
March 20, 2019 at 1:32 pm #171600
I’m still trying to solve the mystery of why my coil conversion is not working out,
trying to use a B&S coil on the Neptune’s twin, opposed cylinder, Eisemann
laminate, while others have supposedly been successful. One person in the club
did this, but his coil was oriented 90 degrees different than mine.
Some Maytag fellows have done this conversion with success, while
one said he had poor low speed spark.
Photos attached tell some of the story.Did some more research, thinking and testing
on the B&S coil conversion on the twin Neptune.Lots of information on Smokstak with people trying
this conversion on their Maytags using the same
Eismann 72 coils.The secondaries on the old Eismann and evidently
the B&S coil I’m attempting to use, Smokstak is
referring to this type as “Pass thru” secondaries,
that is the secondary is not grounded to anything,
and in firing a twin cylinder engine, the spark
travels through one secondary plug wire, through
the spark plug, through the engine block, through
the other spark plug, and back to the coil.This would explain why I was having trouble testing
the B&S coils on the Stevens tester by grounding
one secondary to the laminate, and the other secondary
plug wire to Stevens test lead. It would take high amps
to fire the coil on the tester, and would start arcing
to ground between the coil and laminate.
Pretty sure I’ve tested Opposed, twin cylinder Johnson
in this manner with no problems. Are those coils
designed differently?I found a testing procedure in the Merctronic manual
(have manual, but no tester) that shows testing such
coils by hooking up one secondary to the test lead,
and the other secondary plug wire to the Test Probe lead.
Tried this procedure on my Stevens, and worked great
on the B&S coil mounted on it’s original laminates,
firing the coil stead at 1.5 amps.
When I un-mounted the coil from it’s laminates, the
coil would not test at all.
When I put the B&S coil on the whittled down Eismann laminate,
it started to fire, but not until very high amps. (around 4 amps)What’s the reason for the coil only firing good on it’s original
laminates, not firing at all with no laminates, and very poor
on the Eisman laminates?
I presumed the Stevens was supplying voltage to the primary
circuit and the laminates would not be needed for testing.I re-read all of Mohats articles on magnetos last night,
but alas, I’m still at a loss on what’s going on!Ideas welcomed, brilliance greatly appreciated, lol.
More on this saga previously posted here……
https://aomci.org/forums/topic/1936-37-neptune-ob64a-6-hp-opposed-twin/Thanks!
March 20, 2019 at 2:38 pm #171610It MUST have lamination’s thru the coil or no tester will test it… Don’t ask me how I know…LOL That is how the field is created, without lams, no field..
classicomctools@gmail.comMarch 20, 2019 at 5:37 pm #171632It MUST have lamination’s thru the coil or no tester will test it… Don’t ask me how I know…LOL That is how the field is created, without lams, no field..
Richard, Guess I forgot about the part in Mohat’s article about the “iron core”.
For some stupid reason I was thinking the Stevens was supplying
juice to the primary, enticing the secondary to get all happy.
Will have to keep that in mind for future testing, but that still doesn’t
explain why my modified Eismann lams aren’t working in the
B&S coil. Mr Tesla, where are you!
Thanks.Prepare to be boarded!
March 20, 2019 at 6:28 pm #171634No Tesla here, that is for sure. I guess I would put the BS coil back on its original lamination and restest….If it performs as it did originally, then something(s) about the laminations are different…
One thing that I am noticing is that the winding is offset by 90 degrees on your weisman lamination….And, the outer laminations are farther away from the winding also….March 20, 2019 at 7:58 pm #171637No Tesla here, that is for sure. I guess I would put the BS coil back on its original lamination and restest….If it performs as it did originally, then something(s) about the laminations are different…
Fleetwin, thanks for the input. I did put the B&S coil back on it’s original lams and it tested good
on the Stevens, so the problem must have something to do with the Eisemann lamminations.
I can’t see how the coil would care about it’s orientation on the lamination, but indeed,
the Briggs lams are a completely different design, and for some reason, have a different
color coating on each half.Prepare to be boarded!
- This reply was modified 5 years, 1 month ago by Buccaneer.
March 20, 2019 at 9:38 pm #171643When I first got my Neptune OB64 I tested the coil on Merc O Tonic got no spark. They I checked with Ohm meter and results confused me. Here is how I got a spark using the tester. Connected both plug wires to plugs then put the plugs on small piece of tin and clipped jumper wire to tin one end and the other to tester ground lead. Connected red power lead to coil primary and primary ground to tester ground. They I had spark both plugs. You know some of the B & S coils have electronics and don”t need points.
March 20, 2019 at 9:40 pm #171644How’s your flywheel? Maybe the magnets need a charge.
March 20, 2019 at 10:08 pm #171647Thank for your replies Mercuryman and Mumbles. When I was pulling over the
Neptune to check for spark, I had both spark plugs screwed into an aluminum bar
that was grounded to the engine, so the circuit in the secondary was complete,
but I only got very weak spark, sometimes none.
I believe I have the testing procedure figured out on the Stevens for these type
coils, and the B&S coil test good on the tester, but only when it’s in the original B&S laminates.
The flywheel magnets seem to have decent pull, and I’ve kept a metal bar between
the magnets whenever the flywheel has been off.
Confusing that magnetism and electrical stuff is….. can’t
even see the darn stuff!Prepare to be boarded!
March 20, 2019 at 11:03 pm #171649An observation… the B&S laminations apparently form a magnetic flux loop around the coil. That piece of insulating paper in the lamination gap is “invisable” to the magnetic flux. The Eisermann lams do not form the same loop. Now how or if this difference is what’s causing the problem, I can’t answer. Only an observation.
Looking at the photo again… try testing the coil on the Eisermann lams with the assembly laying in the flywheel so that the lams and the flywheel magnet form a loop … imitating the loop on the B&S set -up
- This reply was modified 5 years, 1 month ago by joecb.
March 21, 2019 at 8:42 am #171659An observation… the B&S laminations apparently form a magnetic flux loop around the coil. That piece of insulating paper in the lamination gap is “invisable” to the magnetic flux. The Eisermann lams do not form the same loop. Now how or if this difference is what’s causing the problem, I can’t answer. Only an observation.
Joe, interesting thoughts on the magnetic field.
One thought I was wondering about was if the B&S coil was “polarization” sensitive
somehow. Out of my league, lol.
I’ll try the Stevens test you suggest……… maybe that will jump start some life into it!
