Home Forum Ask A Member Can anyone ID this boat?
  • #10117
    49morphew
      I recently purchased this boat for my 14 year old daughter. I can find no markings or numbers on the hull or transom and it’s obviously been painted cookie-monster blue. I’m wondering if it is maybe a Starcraft Holiday from the late 60s? Any help is
      #77210
      nj-boatbuilder57
        No clue…..but what an awesome, cool little boat!
        #77212
          I don’t know why, but Starcraft popped to my mind also. I guess maybe because I used to have a Starcraft?
          #77213
            It has a registration number. Doesn’t that say something? Did you get the title?
            #77216
            amuller
              I don’t know, but that Wisconsin registration number should be able to connect you to some information–though boat descriptions are often incorrect. Likely it’s before the time of standardized format hull numbers, but there should be a data plate of some sort. Has the transom wood been replaced? One possible place to look is under the control box.
              #77224
              shoestringmariner
                starcraft dart? Great little boat
                #77234
                49morphew
                  Thanks for the comments and suggestions guys. The registration lists the make as "Mirr" perhaps as in Mirro or Mirrocraft? It does not give a model year. There is a serial number but I can’t seem to find where they got the number from. Searching Mirrocraft boats comes up with no images that resemble this boat. I also read that Mirrocraft produced boats from 16′ on up. This boat is 14′ long. The closest boat I could find that looked very similar was the Starcraft Holiday. After ShoestringMariner’s post I googled Starcraft Dart and that looks to be an even closer match. Thanks for the tip! It has a 1980 Evinrude electric start 35 on it that starts and runs beautifully. It also does not leak at all. It has a few "custom" modifications to the interior that need to be remedied and the paint job could stand to be redone but overall a pretty nice little rig.
                  #77263
                  chinewalker
                    Not a Starcraft. I’ve owned several and the chines and lap stampings aren’t right.
                    Pretty sure it’s a Mirrocraft. Check this thread out:
                    https://forums.iboats.com/forum/boat-re … -resto-mod
                    Stampings are right, rivet line is right.
                    #77306
                    joecb
                      MiroCraft… I have a 12 ft Mirocraft that has the lap stampings like yours. As for ID tags, my boat has flimsy plastic "MiroCraft" plates riveted to each side below the gunnel about 10 inches forward of the transom. Check for signs of three rivet holes in a line spanning about 9 – 10 inches in that location. If the plates are missing the holes or rivets should still be there.
                      #77405
                      49morphew
                        I stand corrected. I think between Chinewalker and JoeCB you guys nailed it down. Thanks for the input. I had not come across any Mirrocraft boats that resembled that one. After further look I can even see how the back to back seating would have been the same in mine based on where the brackets are mounted and the way it’s set up now. Thanks again guys!
