Home Forum Ask A Member Can you help identify this Firestone Motor
  • #177117
    seahuntboater
      The model plate is disintegrated. I can see there is a label under clear plastic on the front bottom housing that says “7 1/2 special”. Trying to determine model name and a year or year range . Thanks.
      Some pics are at : https://drive.google.com/open?id=1XDYbCZioD3KiBjzxQ8F7ncbgaNB5vIfF
      #177118
      Tom
        Can’t tell for sure, but it’s made by West Bend. They made the 10A131 7.5 hp in ’60 and ’61, and they made a model 7001 in ’62.
        T
        #177123
          Yep, a West Bend. Actually evolved from the pea-green Sears Elgins of the ’50’s with a fiberglass cover.
          #177135
          seahuntboater
            Thanks Tom,
            Other than the model plate is there any other way to tell year from numbers on the engine such as the flywheel, or other places? Thanks
