Home › Forum › Ask A Member › Carb kits
  • #979
    mike n
      Hello.i have a 1963 40hp evinrude 40353d.what is the correct carb kit for this engine.where do I find the listings for carb kits for 50’s and 60’s johnson and evinrude . It doesn’t seem to be in the parts manuals.
      mn
      #12444
      avery-omc-parts
        Carb. kit is 439074 for your 40hp
        #12455
        DAN ANDERSON
          You find the part numbers in the OMC Parts and Accessory manual. I have a 2006 copy. The part number given is correct.
          Dan in TN
          #12489
          mike n
            Thank you.is that parts and accessory manual easy to find
            mn
            #12494
              You can also use the back-door approach and look up the Sierra number, then look at their "replaces OMC*****" number.
              #12497
              DAN ANDERSON
                The back door approach Frank mentios works. EBay has them, but you have to know what you are looking for. The sales brochure is what you are looking for primarily, not the parts book one. In this case I would want one a little newer. I have a 2003. That is new enough to have most of the latest part numbers. You can always go to Marine Engine.com and SS to the latest part number. They usually give you the Sierra number option also. I really like OMC/BRP carb. kits because they have all the parts included in the kit of the best quality.
                BTW: With one of these books you get all of the impellers, water pump kits, tune up kits, fuel pump kits, etc. So you are not just getting one thing, but all of the parts and accessories for all of OMC engines of the day.
                Dan in TN
