Home Forum Ask A Member Carbon Seal Question
  • #7441
    david-bartlett
      On the OMC motors that use a carbon seal, does it matter which way the seal goes in? One side of the seal has 2 small "notches" in it, presumably to let oil in or out.
      What is the correct way?
      Thanks, David
      #60367
      david-bartlett
        OK, In the Johnson Service Manual in Garry’s dropbox, it says to install with notches "Up". I guess I am all set with my answer.
        #60370
          Yes that is correct. Notches towards the powerhead. So UP is correct for the lower crank seal.
          #60375
          david-bartlett
            Chris,
            Thanks for confirming that for me.
            #60376
              "UP" means up towards your face. Think about it, the seal does its job by the flat side being in contact with the flat of the bearing shell.It wouldn’t do much good if the notches were against the shell, would it? The new seal design removes all doubt.
              #60430
              david-bartlett
                OK, so using the old style seal on the bottom bearing of an 18hp the side with no notches would go against the bearing?
                  Yes, side with no notches goes against bearing. BTW, that is the newer style in your pictures
                  #60435
                  david-bartlett
                    Frank,
                    Thank you for clearing that up. I was expecting the "New" style to have more of a step.
