Home › Forum › Ask A Member › CD-14 Upper Drive Shaft Seal
  • #183580
    drifter
      Is there anything special about the cork upper drive shaft seal p/n 303355? Can an effective seal simply be made from sheet cork gasket material of the same thickness?
      Drifter
      #183587
        I don’t see why not, as long as you have confidence in the durability of the material.
        #183588
          I use rubberised cork material with good results. Not pure cork.
          If you work on any larger two or three cylinder motors, the air box cover gasket will come stamped out of a sheet of the correct material and the extra material is perfect for these six horse seals.
          #183600
          drifter
            Thank you gentlemen. I have ordered the rubberized cork.
