Home Forum Ask A Member CD-15 Water pump kit; valid ?
  • #288492
    seahorsedad
      Hello all experts;
      Been away for a bit. Back at the ’58 CD-15 rebuild. Scraping around the Web and happened upon a water pump complete kit rebuild, #0763758, though not in the parts manual or Marine Engine, etc. Any thoughts appreciated. I think there is a caution on metal or plastic impeller housing.
      Thanks TIA
      Donald
      #288494
      RICK EICHRODT
        US Member - 2 Years
        Yes, it is a valid BRP replacement water pump kit.  Now this is the smaller impeller with a plastic housing and a metal core liner.  Once you switch to this kit, you must use the smaller impeller.  Not knowing what your old water pump looks like, I would just install a new impeller kit #379764.  I hope this helps!
        Regards,
        Rick
        #288496
        seahorsedad
          Thanks a bunch Rick. I didn’t drop the lower unit yet but now I know what to do. I’ll look into the #379764 as well.
          Have a Great Weekend
          #288562
          crosbyman
            Canada Member - 2 Years
            you do know the head must come off to free the shift linkage   …..got the bible on your oldy ???
            https://watercraftmanuals.com/outboard/johnson/manuals/johnson-302231.htm
            #289129
            seahorsedad
              Yes Crosbyman I have the powerhead off. Thanks for the link to the manual.
              Have a Great Weekend !
