Home Forum Ask A Member CD-?? Engine cowl
  • #44417
    Steve A W
      US Member - 2 Years
      My ’55 CD12 doesn’t appear to have ever been painted and
      it doesn’t have white or silver trim.
      I knew it looked different and never thought about it until I was
      fishing along side my nephew with his ’54 CD12. His has white trim.
      Steve A W
      Member of the MOB chapter.
      I live in Northwest Indiana
      #44424
      fisherman6
        Steve, I could certainly be wrong here, but yours looks to be a darker shade of green than the original CD-10 thru 12. I’m thinking it has been painted at some point too.
        -Ben
        OldJohnnyRude on YouTube
        #44425
          Steve,
          That is a very old restoration, but not original.
          #44427
            Kyle,
            In your case, you have to combine paint combos, and decals, to get the whole story.
            Your first picture shown is a 1954 cowl. In ’54, they had the silver trim, with wing nuts. Looking at starboard side of cowl, in the bottom left corner, they had the Sea Horse picture on top, with the "Sea Horse" script BENEATH the picture, and then the 5 1/2 number beneath that. ON the front of the cowl, beneath the rope start, the ’54 either has a Sea Horse picture, with "Sea Horse" script, OR they have starting instructions. Im not sure on difference there sorry but have seen both.
            Your second picture shown is a 1955 cowl. In ’55, they had the white trim. In the bottom, left corner of the cowl you can see the "5 1/2 number with "Sea Horse" script underneath it, NOT on TOP of it. That also gives it away, as does the fact that there is NO Sea Horse picture, just the script and number. On the front of the ’55 cowl, beneath the rope start, they have the picture of the Sea Horse, with the number 5 1/2 overlayed on it. NO SCRIPT on the ’55 front.
            Hope this sort of helps. I can email you some pictures from original brochures if you want.
            #44428
              Here are the 2 so you can see the differences. Top pic is ’55, bottom pic is ’54.
              wedgie
                dan-in-tn
                  Chris P; I have those same ads you do. Thought I had this all figured out, but guess not? Sorry Kyle guess the answer from my perspective is Im not sure.
                  I also noted in the ads the old which is correct for low speed needle knob? Round or lever? I have seen this for years on CD & QD models. The low speed round knob never looked right to me before as a round knob with a high speed lever. (I call it a lever because I can’t think of anything else proper to call it?) The ads show ’54 vs ’55 the way it should be "I guess"! Still looks weird to me. At least it explains why you see so many with what appears to be wrong knobs that don’t match. I hope someone else can be more precise Kyle.
                  Dan in TN
                  #44491
                    Wedgies pictures show the uncommon ’55 cover with the thumbscrews on the sides.
                    These are few and far between.
                    #44505
                    1946zephyr
                      Yep, the thumb screws were eliminated after the 1955 model cd-12 started production. The first cd-12’s did have thumb screws.
                      #44510
                      david-bartlett
                        Wedgie’s motor is a Canadian model as well. That could be a factor.
