Home Forum Ask A Member Champion outboard
Viewing 10 posts - 1 through 10 (of 22 total)
  • #11247
    sljohnson
      I Purchased to 1946 champion 1J blue ribbon outboards I would like to rebuild the carburetor and reseal the lower unit can anyone help me on where to find parts and schematics ?
      #83083
      retiredoz
        Discount marine says they have the carb kit (Tillotson ME-1)
        #83086
        cajuncook1
          cajuncook1
            cajuncook1
              Look at the pdf below. It shows the different motors from different makers that use the Tillotson carburetors. Some of those share the same needle and seats as well as gaskets numbers and kit numbers. May make it easier to find what you need.
              #83151
              sljohnson
                That book is great help. Does anyone sell parts for the Champion outboards?
                #83174
                cajuncook1
                  As far spare parts for your, you would have find a parts motor. You can place a want Ad here on the AOMCI Webvertise section. There many members that have Champion parts motors. As for as the carburetor, retiredoz made an excellent suggestion for a carburetor kit or you can make the gaskets yourself.
                  quote :
                  In regards to the ignition, test your ignition to see if the coil, points, and condenser are still good. If you need to replace the spark plug wires, then you should get 7mm copper core wires and not the automotive stuff. You can purchase 7mm copper core wires at local lawn mower shop, Tractor shops, and some automotive shops. You can even get them on Amazon.com.
                  https://www.amazon.com/Black-Spark-Plug … +and+boots
                  If your coil is bad, then you will have to identify the type of coil and report back to the forum for suggested replacements.
                  Your gearcase uses grease and not gear oil. Good gear case grease are Corn Head grease and Lubriplate 105.
                  Cheers,
                  Cajun
                  #83179
                    It would appear it is a Bendix Scintilla mag / coil. AKA Mercury.
                    #83261
                    sljohnson
                      What spark plugs work in the 1946 champion 1j?
                      #83262
                      rco
                        It originally called for a #9 champion plug which supercedes to a D21.
