Home Forum Ask A Member Champion R-7 Spark Plug alternative?
  • #9770
      I’ve been trying to cross reference the old Champion R-7
      spark plug with a modern equivalent searching on this
      site and elsewhere, but not sure what to believe.
      One search suggest using Champion 506, which
      shows up as a "resistor" plug, and another suggest
      Champion D8 which seems to be an obsolete number.
      I’m told the R-7 was considered a "racing" plug.
      What makes it so?
        The Champion 506 replaces the R7, NGK AB7 . . . The side electrode in the R7 was thought to give a more open spark for faster ignition – 😀
        #74969
          Garry, Thanks for the reply. EBay is calling
          the Champion 506 a "Resistor" plug,
          which is taboo for magneto ignition from
          what I understand. Correct?
          outbdnut2
            Not sure about an R7, but a Champion 7 is now a Champion D16.
              Yes – resister plugs are only used only in CD ignition systems – I don’t know how that resistor snuck in their . . . 😎
              #74977
                I seen a YouTube video where a guy removed the resistor inside
                a sparkplug, and replaced it with a piece of solid copper wire.
                Anyone try that?
                david-bartlett
                  I would use the NGK AB7. I have used the NGK’s with good results.
                  #74983
                  westwind
                    Autolite 373 is nonresistor and should match the R7 OK too.
                    #74990
                      Thanks David and Westwind. Looks like both
                      plugs are readily available too!
                      Just bought the NGK AB-7.
                      They’re exactly in the middle of the NGK heat range,
                      as is the original specified Champion R-7
                      The AB-7 specs show it as Non-Resistor, 1/2" reach and
                      with a removable nut. Perfect!
                      Shell
                      Thread Size: 18mm
                      Thread Pitch: 1.5mm
                      Seat Type: Gasket
                      Resistor: No
                      Reach: 12mm (.472")
                      Hex Size: 13/16" (21mm)
                      Terminal Type: Removable Nut
                      Overall Height: ISO
                      Gap: .028" (0.7mm)
                      Center Electrode
                      Material: Nickel
                      Type: Standard
                      Projection: Non-Projected
                      Ground Electrode
                      Material: Nickel
                      Type: Standard
                      Quantity: 1
                      Specifications
                      Torque Specs: Cast Iron: 25.3-32.5 lb. ft. Aluminum: 25.3-28.9 lb. ft.
                      Brand: NGK
                      Heat Range: 7
                      Longevity: 30k
                      westwind
                        It’s surprising how many of the old plugs are still available. I ordered some for my Row Boat Motor, almost 100 yrs old and plugs are still available.
