Home › Forum › Ask A Member › Changing the line fitting o-rings on a Mercury gas tank
- This topic has 6 replies, 4 voices, and was last updated 8 years, 10 months ago by
billw.
June 22, 2016 at 10:06 am #4561
How about you guys? I didn’t get any response on John’s old Mercury site, which is unbelievable. I want to replace the rock hard o-rings in my metal, six gallon, single line, Mercury gas tank. This is not as easy as it sounds. I figured out that I need dash 111 o-rings but how to get them in there is a challenge. Is that fitting pressed together? Screwed together? Anybody ever tried this? Thanks
Bill
June 22, 2016 at 12:20 pm #38745Bill I’m glad you asked this question. Sorry I don’t have an answer but I look forward to any advice someone can give. Dave B has probably come across this question or has possibly even tried it.
I’m pretty sure they still sell the whole fitting. I’ll bet most people just get the entire fitting.
June 22, 2016 at 8:01 pm #38778I noodled around on the innanet one night for a couple hours looking for the same info. I even cut an old one apart to see how it was assembled. Then I bought a new fitting…
LarryJune 22, 2016 at 9:07 pm #38783I’m homing in on it. I ordered dash 111 Viton o-rings, only to find they were too small. They are not thick enough. They are the same size as the ones I took out, that shrunk!! I have some dash 205s coming for tomorrow that I hope are right.
I figured out how to relieve the spring tension on the check ball, so you can work the o-rings: You pull the unit out of the tank and unscrew the pick-up tube. Then, push in on the ball and stick a small screw driver in the inlet tube mounting hole, to catch and hold the compressed spring. You are then free to work on the o-rings without the check ball being in the way. More tomorrow, when the hopefully proper o-rings come.
I made a cut-away of a female, fuel line end, which is similar in construction, so I could see how it was made. It is a press-fit and tight; so you don’t want to go trying to turn it or pull at it, because I believe it will break the little tabs that retain the male end…….
June 22, 2016 at 11:13 pm #38789Are we talking about the 2 line fitting from the the tank to the motor? I think I asked how to change the Oring in a Merc connector a LONG time ago and got no response, if I remember right. I would guess you depress the "plunger?", dig out the old Oring, lube up a new Oring and I’ll bet it slips right in. Kind of like changing the Oring in an OMC shift shaft housing.
June 22, 2016 at 11:51 pm #38792I’m talking about the single line fitting that you push in and twist, to lock. There are two o-rings in there, separated by a floating washer. The first one is pretty easy but the second one was a problem, until I figured out the trick to holding the ball back, above.
June 23, 2016 at 11:52 pm #38841The dash 205 o-rings are the ones. I greased -em up a little and they went in with some finagling. The trick is definetly holding the spring back, through the pick-up tube hole.
