Home Forum Ask A Member Changing the shift rod seal on my Johnson CD-12
Viewing 10 posts - 21 through 30 (of 35 total)
  • #53126
      Here’s another simple tool used to install them.
      fisherman6
        I made a bushing installer very similar to the one Mumbles pictured above. The main difference is the smaller diameter portion that passes thru the bushing goes thru far enough to hold the O-ring so the whole assembly can be inserted with the tool at once.
        -Ben
        OldJohnnyRude on YouTube
        #53132
        crosbyman
          I simply used a ratchet socket at the end of an extension to match the diameter of the brass insert
          the socket needs to be simply driven squarely with the beveled edge of the brass insert facing down
          #53134
          necks
            After you spent all this time and money on the lower unit, you should pressure test it to make sure there are no more leaks elseware.
            #53137
            fisherman6
              Yes indeed. Always pressure check after resealing and prior to refilling. If you still have leaks, that’s the time to fix ’email.
              -Ben
              #53139
              steeleman
                quote Fisherman6:
                -Ben
                When I did mine I replaced everything while I was there anyway. What do you guys use to pressure test? I have been wanting to try that anyway
                #53140
                fisherman6
                  Steven’s Instruments makes a nice self contained pressure tester.
                  http://www.stevensinstrument.com/gearcase.htm
                  I made one that I use with regulated air pressure from my compressor. Mine looks like this.
                  -Ben
                  #53148
                    US Member - 2 Years
                    Scoots,
                    How I installed was with the shift shaft just in place with the O-ring & bushing placed on the shift shaft. I slid the O-ring down to the cavity & bottomed out. Next slid the bushing into place & using a small punch tap around the bushing to seat it in place.
                    Next check for firmness on the O-ring moving the shaft up & down. This way no chuncks of rubber are removed & get a tight fit with the O-ring
                    #53155
                      Good idea Jeff and I do have another bushing tool with a longer snout on it for just that reason. As I tap the bushing in, I move the tool up and down a bit to feel the tension of the O ring on the snout. Smearing the cavity with Triple Guard grease before inserting the O ring can help to keep water out and corrosion down to.
                      #53166
                      johnyrude200
                        There was an OMC tool that you place the bushing an O-ring on, then seat the leading (tapered) edge of the bushing, then tap it into place. I have a few of them. Only thing – don’t try to whack that bushing in TOO far, that orifice can and will crack. Does require some ‘feel’ for the job and experience. I usually will try to pull the installer out once it feels/sounds as if it’s bottoming out, and if it is a tough pull that means the O-ring is being squashed down and compressing the installer tip.
                        That’s what we want, a snug seal around the shift shaft. I reinstall the shift shaft with grease to minimize any sort of risk of tearing/gouging the new o-ring too.
