Home › Forum › Ask A Member › Charging 85 hp 1972–upgrade stator?
- This topic has 21 replies, 4 voices, and was last updated 7 years ago by
frankr.
July 26, 2019 at 2:30 pm #180318
I am sort of unclear whether to post this here or in the tech section, but there seems to be more traffic here. Opinions?
OK to the subject: The flywheel alternator on this motor is rated, apparently, at 9 amps. There is an upgrade kit which is rated at either 15 amps or 12 amps depending on where you look.
The motor does not seem to charge much, though I have checked out the stator and replaced the rectifier. Is it worthwhile to upgrade to the higher output stator?
OMC apparently sold a kit including a regulator and an ammeter, but the stator itself is cheap.
Is there an easy way to tell which stator is which?
Thanks.
July 26, 2019 at 3:33 pm #180319I guess you must be needing more charging or you wouldn’t be asking. Just wondering though, why?
This reply was modified 7 years, 2 months ago by
frankr.
July 26, 2019 at 8:10 pm #180331Me too, don’t ever recall having an issue with the battery CD charging systems…
Have you put an ammeter inline to check the actual output?
Keep in mind that there are two other items that tie into the alternator output that could have an effect…
The shift diodes….These diodes AKA “monkey balls” are tied into the stator to supply current to the shift solenoids so the engine will stay in neutral when the key switch is turned off and the flywheel is still spinning…A quick test is to shut the engine off while at high idle in neutral…If it slams into forward gear before shutting off, there is a problem with the shift diodes…
This engine also has what is called the “clipper circuit”, which is really just a basic regulator…The clipper circuit kills half the alternator output if it senses high voltage, such as a loose/corroded battery connection…So, if this unit is messed up, you will only get half of the alternator output…But, keep in mind, the clipper might actually be doing its job because it is sensing high voltage!Again, I never encountered an issue with these 9amp systems not keeping up with basic electrical needs, so I would check the items I have mentioned before investing in an expensive larger output stator…Would love to see any info you have on this kit, don’t remember anything like that being offered…
July 26, 2019 at 9:59 pm #180339July 26, 2019 at 9:59 pm #180340July 27, 2019 at 7:47 am #180344I’ll be darned….Wonder why the rectifier is included, couldn’t the old one be reused? Wonder if the original clipper circuit is still used in conjunction with that regulator? Very interesting…
July 27, 2019 at 8:09 am #180345Not sure about the rectifier, but I assume the original one can’t stand the amperage. Also can’t answer the clipper question—don’t know.
July 27, 2019 at 9:04 am #180347Yes, that’s the kit I was looking at. And the stator is only $20, so I might order one. There are various rectifier numbers, with varying numbers of leads and some claiming to be “regulated” and some not. Sometimes there is a separate regulator, sometimes not. Is the kit intended to be used with a rectifier, a clipper, and a regulator? Hard to tell without the instruction sheet for the kit. Some sources recommend removing the clipper as doing more harm than good…. Then there is the advice to NOT use sealed batteries, which are pretty much the only type readily available these days. This kind of makes sense when the charging source is unregulated, as water will be boiled out of the battery and not readily replaced.
July 27, 2019 at 9:47 am #180348As I understand it, (some) of the aftermarket amplifiers have built-in overvoltage protection so they say the clipper is not needed for those. That’s all I know. Been too many years since I got away from them. Or maybe not enough years?
July 28, 2019 at 8:56 am #180391Keep us informed if you purchase this kit….Will be interested in the contents, and the instructions!
