Home Forum Ask A Member Checkup for good running motors
  • #1438
    stanley
      I have a few old motors (1930 vintage) that I was able to get running with a good cleaning of fuel system and some ignition work.They run great in a barrel.Should I go ahead and check pistons etc.just to be on safe side or not mess with a good thing and start using them?
      #15556
      billy-j
        I think you already answered your own question. THEY RUN GREAT. I would lubricate everything that moves or slides and lubricate lower unit and give it a go. Bill,
        #15563
        Doug Wilson
          US Member - 2 Years
          I agree with Bill, I did that with a Johnson A-50 last year seems to run pretty good on the boat too. I decided was worth a try and am going to try the same thing on a K-50 that wandered in. If you were going to be running them a lot day after day then might be worth tearing them down but for an occasional run think I would risk it.
          Doug
          Doug
          turned off?
          #15567
          stanley
            Coincidentally,the two I most want to run are anA50 and a KA38.Both have good original paint and I didn’t want to mess it up.I read a previous post about the aluminum "spark arresters" in the A50 getting eaten and got concerned.I’m pretty sure those are fuel atomizers on the intake ports.
            #15573
              Don’t forget, the KA 38 requires 8:1 fuel mix!
              #15574
              stanley
                I saw that.The first time I saw it I thought it was a typo.I’ve been doing that ratio withTC-W30 for tank tests,is that OK for longer use ?
                #15578
                  The KA has a large rotary valve with two sealing rings on the crank so that is probably why it needs the heavy oil mix. I wouldn’t change it as they don’t make these parts any more.
                  #15580
                  stanley
                    So the TW-C3 2cycle oil is ok?What do you use in yours?AND thank you for all the info.
                    #15626
                    Doug Wilson
                      US Member - 2 Years
                      the standard tc-w3 outboard oil is what I have been using,the A50 I ran at 16:1 will have to check and see what it should run. Last time out wind kicked up @ 20-25 it just pushed on through it on a 14′ boat pretty pleased.
                      Doug
                      turned off?
                      #15651
                        Sent you a PM.
                        Check your messages
                        top right of this page.
