Home › Forum › Ask A Member › Chris Craft Commander
- This topic has 23 replies, 9 voices, and was last updated 4 years, 4 months ago by
Sean Shoemaker.
October 22, 2021 at 1:39 pm #248481
Thansk to Dave’s insight that the Bendix points were / are still used on aircraft engines I was able to locate a set and they are on their way. With any luck I will find the cowls, tiller arm, and lower unit parts and get this thing running.
October 22, 2021 at 4:32 pm #248488You are welcome
October 26, 2021 at 7:34 pm #248727If you are still looking for a tiller handle I recast them
October 27, 2021 at 7:36 am #248739yes, i’d be interested. feel free to message me.
October 27, 2021 at 6:28 pm #248770My name is Bruce Reinhart and I am in Ontario Canada , I have re cast the Chris Craft Commander handles. They will need the holes drilled and fitted to your motor
I sell them for $35.00 plus shipping
If you are interested you can email me at
bruceter00@gmail.comApril 29, 2022 at 5:13 am #259150Now that the weather is just starting to warm up here in Wisconsin I would like to get back to this project. I was able to acquire the points and handle for this. (Thanks everyone) I would like to get the coils and impeller figured out. If there is a member that would be willing to show what is behind the prop to see what I am missing. I’m guessing an aluminum disc to cover the impeller that is held in place by a retaining spring, the impeller , and a key?
I did find the military surplus coils for this but I never did order them. Unfortunately I lost my info/source on what the correct numbers are and where to order them.
Any help would be appreciated.
This reply was modified 4 years, 4 months ago by
Sean Shoemaker.
May 1, 2022 at 4:13 pm #259270Is this what you’re looking for?
2Fast4Me
May 2, 2022 at 10:56 am #259311
May 3, 2022 at 12:14 pm #259371Thanks for the pics, guys. I think I can figure out the coils.
However I have further questions about the impeller cover. I see a center raised section. Is this a housing for a seal? Is the center bore oversized to clear the prop shaft and the impeller is peeking thru the hole?
Sean Shoemaker.
May 8, 2022 at 10:01 pm #259602Just for further clarification all I have to go on is this low resolution small sized black and white image for the parts I am missing between the prop and waterpump housing. I would like to find another Commander for parts but the nearest one I’ve found so far is 8 hours away and 900.00. Due to the rarity I may have to have them machined . But this is hard to do without proper images / dimensions.
