Home › Forum › Ask A Member › Clinton engine corp outboard problem.
- This topic has 9 replies, 5 voices, and was last updated 3 years, 2 months ago by
Tubs.
February 27, 2022 at 11:30 am #255350
Hello,
I have a Clinton Engine Corp L750 3107 series
My serial number is 9994476
Type # XTV 52207I bought this outboard used, and there is no spark, so I took it apart to investigate.
It looks like someone did a number to the flywheel with JB weld, causing the timing to be off. Like the flywheel spun and stripped the Keyway.
Does anyone know how to repair this, or….know anyone with parts for this Outboard?
February 27, 2022 at 12:27 pm #255352Could the flywheel keyway be machine to fit a larger key?
They a stepped key could be used, keeping the original size
for the crankshaft. Of course, you’d have to keep the “timing”
in mind when machining the flywheel.Prepare to be boarded!
February 27, 2022 at 2:25 pm #255368If you try this place, please report back and let us know if the info is still good.
Clinton Engines Corporation
22563 35th Street
Maquoketa, IA 52060-8640
(563) 652-2411They are a “cash” only place, they don’t accept credit cards. If they are not there leave a message, and they do get back to you. tell them what you need, they take your order, then call you back with the price for parts and shipping.
February 27, 2022 at 2:43 pm #255369Could the flywheel keyway be machine to fit a larger key?
in mind when machining the flywheel.It looked like they jammed some JB weld in the damaged area, and smashed it on the crankshaft…maybe with wax so it wouldn’t stick…and probably had it rotated wrong.
February 27, 2022 at 2:49 pm #255370Could the flywheel keyway be machine to fit a larger key?
in mind when machining the flywheel.Buccaneer, ironically I was talking to a guy named Jeff ward in 2020 about a pdf you sent him pertaining to my outboard:
“Jeff, I saw you had a pdf sent to you by “buccaneer” in 2016
For the L750 3107 series
Type # XTV 52207
I wanted to repair this to get running….no spark……
Is there a chance you still have it and could forward it to me?
Please and thank you in advance!”February 27, 2022 at 6:58 pm #255392Don’t know where the OP lives, If around here ( SE MI) I would say just look for a parts motor. Clintons are pretty common and not to desirable as collector items… like $10 (or free) parts motors, at our swap meets.
February 27, 2022 at 7:50 pm #255410Clinton_Outboard_K753_Parts_List_Manual
This reply was modified 3 years, 2 months ago by
Buccaneer.
Buccaneer.
February 27, 2022 at 9:06 pm #255417Don’t know where the OP lives, If around here ( SE MI) I would say just look for a parts motor. Clintons are pretty common and not to desirable as collector items… like $10 (or free) parts motors, at our swap meets.
I do live in south East Michigan
macomb county
February 28, 2022 at 12:12 pm #255436well, that’s good news, lots of help here at the Great Lakes Chapter meets… hope to see you at our first meet of the season at Lockeman’s Hardware in Detroit, March 26 , there will be big swap and sell area. >>>> bring your motor.
March 1, 2022 at 9:36 am #255458Link-
http://clintonengines.us/Outboards.html
