Home Forum Ask A Member Clunk Test – – Wrist Pin Test
  • #236010
    Mike Nazarenko
      Just purchased a 1957 Evinrude Sportwin 10 hp and have been reading about the dreaded clunk test to test for wrist pin play. Can someone point me to what and where that test my be in the forum and how it correlates to compression and if the motor is worth repairing.
      Thank you.
      #236011
        Rotate the flywheel until the piston is just past top dead center and on it’s down stroke. Insert a wood dowel or screwdriver thru the spark plug hole and push in on the piston. If the wrist pins or rod bushings are worn, you will feel the free play and hear the clunk. A tiny bit of play is probably OK but a big clunk will let you know the engine needs some big work.
        #236120
        olcah
          Sometmes the test can be misleading. Before major disassembly see this thread. If you think there is a problem you can check by removing the exhaust cover and plate.
          https://www.aomci.org/forums/topic/connecting-rod-bearings-1956-johnson-30-hp/
          #236139
          fleetwin
            Well, both points are valid. There will always be a very slight bit of movement due to sideways piston slop against the cylinder. You will know if there is a big problem, you will feel definite movement and hear a clunk. Don’t know if I would pull the exhaust cover though, that is a messy job that usually involves broken fasteners.
            Sloppy wrist pins are usually pretty evident when running the engine also…You will hear the clunking at dead idle, will probably dissipate when the throttle is advanced a bit…
            #236142
            Mike Nazarenko
              Thank you all for the counsel.
              I checked yesterday and there is virtually no play when pushing on either cylinders after top dead center on the down stroke, so I won’t fix what doesn’t appear to be broken and prepare it for the water and see how it does.
              Thanks again.
              #236155
              fleetwin
                Sounds like the perfect approach to me…..
