Home Forum Ask A Member Common problems with the 6V Evinrude Starters?
Viewing 10 posts - 1 through 10 (of 23 total)
  • #242941
    mr-asa
      Got a starter, Autolite MAK 4033M 5K on the tag from what I can tell.
      With it installed on the ’55 25HP it came with I hooked it up to a portable setup I’ve cobbled together that is basically a momentary switch, 12V starter solenoid, and a 12V car battery. Everything is setup correctly (basically I cut out everything but the momentary switch and solenoid from the below) and the starter is getting power but there’s no action.
      Brushes? Do the windings like to burn out? Other?
      #242954
        Did you clean the commutator? Inspect the brushes?
        Lacking a “growler” to check for shorts in the windings, you
        can make sure there’s no “open” windings by checking
        continuity throughout the commutator with an ohm meter,
        holding one meter lead on one segment, and go around the
        commutator with the other lead.
          Try tapping on the starter. If it cranks its likely just
          poor contact of the brushes. This friend of mine
          has been beating on his starter with a rock to
          get this to crank over. Once he gets it started the
          first time its fine the rest of the day. I know but
          its his motor.
          #242969
          mr-asa
            I haven’t checked any of those. Made sure it spun and then hooked it up. Figured I’d look for the most common issues these might have before I start digging in.
            #242974
              Your six volt starter has a band on the bottom which can be removed to inspect the brushes and commutator. The brushes may be worn or hung up. Another issue with these starters is the thrust washer on the bottom of the armature wears out, allowing the commutator to fall a bit and short out on the end plate. I’ve fixed this problem before by making thin washers out of Delrin.The field windings are quite robust but if the insulation has fallen off, they can be rewrapped with cotton and then varnished. I use seam binding meant for sewing to do this.
              Try holding the starter upside down and put the power to it. If it spins and tries to jump out of your hand, you can assume the lower thrust washer is worn out and it has an internal short.
              Starter-Field-Coils-2
              Starter-Field-Coils
              • This reply was modified 3 years, 9 months ago by Mumbles.
              #243083
              mr-asa
                Well… crap.
                At least I know what is wrong with this starter
                #243084
                  Wow, did it use to live on the bottom of the ocean?
                  mr-asa
                    It actually looked pretty dadgum good when I got it. Picked it up for $100 a few years back, came with controls, cables, wiring, fuel tank and fuel lines. Guy basically pulled it off his boat when he upgraded.
                    No real evidence of any water damage. The outboard spun over with no issues. Paint was horrible, but I’ve fixed that by now
                    • This reply was modified 3 years, 9 months ago by mr-asa.
                    #243089
                      This guy can rebuild your starter pretty cheap, but the shipping costs might be a little steep.
                      https://www.youtube.com/watch?v=THES37K3EUE
                      #243093
                      mr-asa
                        Thanks Bob, there’s an actual little Mom ‘n Pop style rewinding shop about 4 miles away from me that somehow is still open. I’m going to try and clear as much of the rust out of this thing as possible and head up there come Monday.
