Home › Forum › Ask A Member › Compression check question
- This topic has 17 replies, 9 voices, and was last updated 10 years, 9 months ago by
legendre.
June 21, 2015 at 10:52 pm #1826
Hi, todays dumb question…
Can i do a compression check with the carburetor off the motor?
Thanks
June 21, 2015 at 11:15 pm #18627I can’t see why not. So long as you have the reed plate bolted down properly it should work.
June 21, 2015 at 11:53 pm #18631Thanks
June 21, 2015 at 11:57 pm #18632Do you even need the reed plate ?
June 22, 2015 at 12:01 am #18633Now that you mention it, I don’t think so. However it might do weird stuff without it. Part of the reason that 2-strokes work is that the reed plate helps pressurize the crank case, so maybe it would need it for the full compression numbers?
June 22, 2015 at 12:09 am #18635on a 4 cycle motor no, but a 2 cycle yes you can no carb no reeds no problem for compression check, only running.
June 22, 2015 at 12:19 am #18637quote Mr. Asa:Now that you mention it, I don’t think so. However it might do weird stuff without it. Part of the reason that 2-strokes work is that the reed plate helps pressurize the crank case, so maybe it would need it for the full compression numbers?I’ve never actually tested this, but I would imagine the reed valve is +critical+ to getting a proper compression reading. Secondary (cylinder) compression is the product of the primary & secondary compression ratios. Without the reed valve, you’re going to lose much of the primary compression, as the charge will be shoved back out of the intake before it transfers to the cylinder.
But other than that, there’s no need to have the carb installed on any engine when testing compression. The carb should always be held at WOT for a compression test, which is not all that different from not having a carb at all..
If the OP has the time and inclination, it would be interesting to see figures posted for compression with and without the reed valve in place.
quote Dave Bernard:on a 4 cycle motor no, but a 2 cycle yes you can no carb no reeds no problem for compression check, only running.Are you saying a 4-stroke engine +needs+ to have a carburetor in place to get a proper compression reading? Sorry, that’s just not the case..
(ETA: LoL, here we go again..)
June 22, 2015 at 12:48 am #18639No carb necessary for a compression check.
The carb is not involved in compressing,June 22, 2015 at 1:03 am #18641My mistake but if the carb is on a 4cycle it must be open to get a true compression .Correct?
June 22, 2015 at 1:05 am #18642quote legendre:The carb should always be held at WOT for a compression test, which is not all that different from not having a carb at all..[/quote]
Actually for our 2 stroke outboards throttle setting is totally irrelevant for a compression test. Hold it at no throttle, half throttle, full throttle, doesn’t matter.
