Home › Forum › Ask A Member › Condensers for Evinrude Zephyr (4404)
- This topic has 19 replies, 11 voices, and was last updated 2 years, 3 months ago by
JACQUES.
September 18, 2020 at 5:58 pm #216800
Jeff is my ( our) capacitor hero ! Can’t tell you how many motors those modern foil caps have brought back to life… and the .22mf size seems to be abut universal
September 18, 2020 at 8:55 pm #216813Just trying to help! Thank you Jim & Joe!!
Best,
Jeff1 user thanked author for this post.
September 19, 2020 at 10:32 am #216850Tubs,
Bet that cap would be the same for the 272, 292, & 312 the T-bird mtr. Maybe a 58 big block 332, early 390 block. Remember those??? I had a 57 Ranch station wagon, the two door version. Put a 1965 Mercury engine 390, trans & pumpkin even fit the axle splines. Stopped for a school bus & was rear ended. It was totaled……Now I am a old guy like the one who hit me. It was a fun build though!!!
Jeff
September 28, 2020 at 9:14 am #217460Be sure to order the caps with the “HQ” suffex. It is a better cap. Can’t believe I remembered that!!
May 8, 2024 at 8:48 am #287692Maybe a dumb question, but as I am NOT an Electrical engineer….On those Vishay caps….is there a positive and negative side, or does it not matter?
classicomctools@gmail.comMay 8, 2024 at 10:44 am #287694foil capacitors re NOT polarity sensitive. they just store electrons on foil.
to read up on capacitors, testing and repair procedure you may be interested in M.Mohat’s excellent articles from past OUTBOARDER issues or the WRAOMCI site
https://wrcoutboards.org/wp-content/uploads/2020/04/Part1_Condenser_Construction_Failure_Modes.pdf
https://wrcoutboards.org/wp-content/uploads/2020/04/Part3_Sizing_Condensers_Correctly.pdf
https://wrcoutboards.org/wp-content/uploads/2020/04/Part4_Repairing_Broken_Condensers.pdf
summay….
Motors, 1900s – (MASSIVE steel magnets, 2 pole / 2 pole construction, absolutely HUGE spark
coils)….use a .68 to 1.0uF condenser. Error on going too large, to protect the insulation in your
antique spark coil if possible…as long as your motor can be started easily.Motors 1910s through 1920s (STEEL MAGNETS, 2 pole / 2 pole construction, very large spark
coil)….use a .47uF to .68uF condenser. Again, error on going larger than this, as long as you
can start the motor easily!Motors 1930s and 1940s (Steel Magnets, typically 2 pole / 3 pole construction, “medium” size
spark coils)….use a .3 to .47uF condenser.Motors 1930s and 1940s, (Alnico Magnets, 2 pole / 3 pole construction, smaller size spark
coils)….use a .22 to .47uF condenser.Motors 1950s and newer (all)….just use a .22uF. It REALLY isn’t at all critical, apparently!
Also note that almost all 12V “Battery and Points” ignition systems seem to use something close
to 0.22uF as well, so this is sort of your ‘universal replacement’ value.Joining AOMCI has priviledges 🙂
May 9, 2024 at 5:04 pm #287725While we are on the subject of capacitors and Jeff is “onboard” , I have a related question for him… I just saw a video ( here ?) about using a new ceramic capacitor as a replacement on our magneto ignition systems. Now these ceramic caps are “teeny – tiny” things about half the size of a “Chicklet”. Jeff help me understand… my feeble understanding of things electrical says the capacitor is analogous to a bucket in a water circuit as it accumulates then dumps the electrons… these tiny ceramic caps sure are a very very tiny “bucket” !!!
May 11, 2024 at 2:31 am #287755Maybe a dumb question, but as I am NOT an Electrical engineer….On those Vishay caps….is there a positive and negative side, or does it not matter?
Nope. As mentioned though, they are bipolar meaning they have no negative or positive leads and can be installed either way.
Depending on design, one lead on a bipolar axial cap is usually connected to the outer casing and can be detected with special equipment. Boutique, or high end (as in expensive) caps usually have this lead marked but it only matters to guys who work on exotic tube amplifiers. Something about they can hear the difference thru their $30,ooo dollar speakers if a cap is installed one way or another.
May 14, 2024 at 5:37 pm #287802Mumbles,
Please describe how to install the cap in a can. I have .22 uF digikey caps but the leads break from vibration in a running motor. How do you connect the leads inside the old can? Is the cap shown wrapped in tape? Would the tall can work on a standard magneto?
Thank you.
May 14, 2024 at 8:05 pm #287805see M.Mohat articles…. the emptied cap can is simply drilled 1/16 on the bottom or the side near the bottom. one leg of the carb is passed to the outside and welded on the can
the tall can may be fine if it does not rub under the fw
the other end is carefully centered in the can and extended with a small piece insulated stand wire enough to reach the points
just center the cap in the can with epoxy and top of with a dab of clear silicone ( no black silicon) .
Microsoft Word – Part4_Repairing_Broken_Condensers.doc (wrcoutboards.org)
