Home Forum Ask A Member Control Cables for 57 Johnson 35 HP
  • #2435
    thompsonboat
      Can the control cables for shift and throttle for a 1957 Johnson 35 HP with corresponding control box be shortened? They are way too long for the boat. If they can be shortened, how do I go about making it happen?
      Andreas
      #23114
      chinewalker
        Much easier to simply find shorter cables. I believe you can take the brass ends and barrel nuts off yours (as well as the connectors) and place them onto the 400 Series OMC replacement cables.
        #23117
        gjonz
          The Teleflex cables are still widely available and not too darned expensive. I’d buy new ones that are the correct length.
          Greg
          #23123
            New 400 cables work SO…. much better than those old thick ’57 vintage cables. All you have to do is change the clips that lock them onto the sides of the motor. Or modify the smaller ones. Or maybe change the trunnions as suggested (?? I’ve never tried that)
            #23521
            thompsonboat
              Thanks for the tips. Where does one purchase these cables?
              #23534
                Any marine dealer can get Teleflex stuff, if they don’t already have it on the shelf. Or of course, any Evinrude dealer can get the "real" OMC/BRP ones.
                #23535
                dave-bernard
                  Ebay is always good.
