Home Forum Ask A Member Correct cotter pin for TD 20 1947 propeller part number 15-84
  • #289464
    paulde51
      The parts book names 15-84 as the cotter pin but as usual it does not name steel or aluminum or the length and or size dimensions.  I am trying to do a really good authentic restoration and wonder if any one knows what a 15-84 was.    Thanks everyone that has helped me so far.  This has really been fun.  Paul
      #289467
        Well if you mean shear pin search Ebay for Olson shear pin and at some point the pin number you’re looking for will show up. Tubs
        A "Boat House Repair" is one that done without having tools or the skills to do it properly.
        #289468
        John Gragg
          The Olsen Shear Pin is a #2, according to notes I took when someone (I believe here) posted the entire listing of Olsen pins.
          Good Luck,
          Best Regards,
          John Gragg
          RIverside, CA
          Just starting in the hobby, please be patient.
          48 Sea King 5hp GG9014A
          49 Sea King 5hp GG9014A
          48 Johnson TD20
          49 Johnson TD20
          54 Johnson QD15
          55 Johnson CD12
          57 Johnson RJE-19M
          57 Johnson RDE-19
          #289469
          John Gragg
            See attached
            John Gragg
            RIverside, CA
            48 Johnson TD20
            49 Johnson TD20
            54 Johnson QD15
            55 Johnson CD12
            57 Johnson RJE-19M
            57 Johnson RDE-19
            #289471
            John Gragg
              Sorry – that’s for the Evinrude motors. I have the Johnson list somewhere…
              John Gragg
              RIverside, CA
              48 Johnson TD20
              49 Johnson TD20
              54 Johnson QD15
              55 Johnson CD12
              57 Johnson RJE-19M
              57 Johnson RDE-19
              #289473
              John Gragg
                Aha!
                John Gragg
                RIverside, CA
                48 Johnson TD20
                49 Johnson TD20
                54 Johnson QD15
                55 Johnson CD12
                57 Johnson RJE-19M
                57 Johnson RDE-19
                #289476
                paulde51
                  Thanks but this for the COTTER PIN part number 15-84 that goes through the propeller nut not the shear pin.   Thanks.   I hope there is a chart similar to the shear pin chart.  Paul
                  #289479
                  dave-bernard
                    any cotter pin that fits. best is stainless or brass
                    #289489
                    oldlure
                      15-84 was replaced by 306365 which is replaced by 302804.  Material may have changed with each substitution, may be steel, I’d go with stainless.
