Home Forum Ask A Member Correct Firestone condenser MFD rating?
  • #1474
      My 50 Firestone 5 hp has the Phelon magneto # F189J
      with condensers that mount horizontal.
      Anyone have info on what mfd. rating the condensers are?
      I looked at some Merctronic info I had, but I could not find
      what I wanted. The info listed Scott Atwater’s of the same vintage
      as my Firestone, but they appear to use the Wico magnetos with the vertical
      mount condensers.
      Thanks, Bucc
      legendre
        If they are like 99% of all other marine, motorcycle, automotive and small-engine condensers, they’re 0.22uF @ 630V (AC). The voltage rating is approximate, but 630V should be a very acceptable figure.
        #15842
          My Merc-o-Tronic manual gives the wico ratings listed by wico part number. I see numbers in the list anywhere between 0.1 to 0.34 MFD. What is your Wico number (stamped on the end of the condenser)?
          #15847
            Don’t these mags use the same Phelon coils as used in Mercs? If so, the ratings are .14 to .18 uF or .15 to .19 uF.
            #15853
              Coils are not like Mercury’s. Didn’t look on the actual condenser
              yet to see if there’s any numbers, but good idea.
              Here’s my mag………
              http://grayhitandmiss.com/Outboards/dscn4911.jpg
                US Member - 2 Years
                Mumbles,
                I agree, both used the same caps.
                #15880
                  Looked at one of the condensers today and there were no markings
                  or numbers of any kind on them. Found a old Prestolite chart
                  showing my Firestone takes their condenser 2-5035…..
                  not that "that" helps, lol.
                    OK, here ya go.. F189J mag uses FG-471 condensers, and capacity is 0.12-0.16 mfd
                    #15883
                      Awesome, Thanks Frank!
