Home Forum Ask A Member Cowling seal/gasket
  • #286246
    CARY PALMER
      Restoring the cowlings on my 1973 Johnson 4 horse & a 1975 Evinrude 15 horse and am looking for replacement cowling seals.
      #286253
      crosbyman
        frequent subject… some slice a small fuel line down the middle and  glue on the rim
        some by the real thing  from…  http://nymarine.ca/cowlgaskets.htm
        or you can investgate  door trims on Amazon which come in diffrent sizes ..
        Edge Trim Black large U height 0.656″ U Height x 0.039″-0.178″ grip range (10 Feet) : Amazon.ca: Automotive
        #286322
          I’ve used the ones from nymarine on a few restorations  and while a bit pricy, they are as the originals and of good quality.  They can be a bit of a challenge to install but it can be done in a few hours using the original staples and super glue/clamps to get them to lay flat.
          http://www.nymarine.ca/
          #286409
          CARY PALMER
            Thanks for the replies fellas.  I went ahead and reached out to nymarine to make sure I get the correct style.  Sure wish I could find it in white since that is what was on the motor.
