Home Forum Ask A Member cracked throttle handle 5.5hp 1959
  • #203233
    crosbyman
      Canada Member - 2 Years
      I have a crack on one side of the two part throttle/steering handle …
      motor must have been dropped and caused a slight bend which caused the crack (about 1/16 to 1/8 is offset)
      are the throttle handles made of aluminum if so I will try to realign it and weld it with those rods alumiweld… or something…
      thanks
      • This topic was modified 3 years, 11 months ago by crosbyman.
      #203235
      David Bartlett
        US Member - 2 Years
        Yes they are aluminum. Also the same part was used on many millions of motors so if you can’t fix it is easy to replace.
        David Bartlett
        #203249
        crosbyman
          ok thanks… I had those welding rods for years in the cupboard in the shed and only used them last year on my “new” to me” 14 foot aluminum boat…. the 2 back corners that had splits I followed the instruction and they worked out pretty well so I give it try when I tackle it later on this year
          … keeping this “gift to me” for my next winter project 🙂 If I break the other half trying to line up the crack I’ll go hunting for a new handle
          #205181
          crosbyman
            update: tiller fixed
            with the left side half, cracked in two I was going to try welding but resorted to Permatex STEEL WELD epoxy with great success !
            I welded the crack with just a touch of epoxy and reassembled the tiller with screws and electrical tape to line up the parts perfectly ..like a broken leg bone
            after an hour I split the tiller back in it’s two separate parts to access the inner side of the broken half. I washed out all the grease/oil , scraped the surface with my Dremel tool for a better grab.
            The parts being hollow there was lots of space to coat the inner surface with epoxy over the crack and for added rigidity I just soaked in a few 2.5 inch spiral galvanized nails over the crack
            Perfect fit , extremely solid and a cheap fix 🙂 Now I just need to figure those darn tiller gears…
            #205218
            fleetwin
              US Member - 2 Years
              Is it an Evinrude or Johnson? I just happen to have a tiller handle from a 1959 Evinrude….
              #205229
              crosbyman
                Evinrude Golden Jubile 1959 Thanks for mentioning it but frankly the repairs look perfect and already coated with fresh paint 🙂 Save that tiller 🙂
                #205280
                fleetwin
                  US Member - 2 Years
                  Cool! I have been so upset lately, my work shop has been more of a dumping ground than man cave. Finally spent a couple of days going through most everything, remembering all the good stuff I have “collected”, that is when I found the Golden Jubilee tiller handle. Now, I can enjoy doing a few projects, but it won’t take long to mess the shop all up again….
