Decisions, Decisions
Home › Forum › Ask A Member › Decisions, Decisions
- This topic has 5 replies, 6 voices, and was last updated 5 years, 7 months ago by billw.
August 6, 2018 at 11:29 pm #10773
I’m not sure which way to go now as I was given a ’76 Merc 200 for parts to try and get the ’69 200 together and running but the ’76 turned out to be a good runner to after I cut a hole in the side so I could cut the frozen driveshaft in half. The ’76 gearcase could use some fresh bearings and it seems it will bolt right on to the ’69 exhaust housing.
What the problem is, the ’76 had been kept outside with a spark plug missing and no wrap or cover to protect it. The motor was full of leaves and spider webs and I just assumed it was seized from sitting. After getting the gearcase off, I blew the leaves off it and tried to turn the flywheel, and it turned. The next step was to oil it up and spin it with a drill to see if it had any spark, which it did on one cylinder. After replacing the bad coil I hooked it up to a garden hose and it fired right up! I was going to trash the ’76 parts motor but now I’m thinking it could be made into a daily driver if I come up with the missing parts for it. So what do I do, finish the ’69 and save the ’76 to? π
Here’s a couple videos of both of them running.
August 6, 2018 at 11:31 pm #80746Work on your Koban….
classicomctools@gmail.comAugust 6, 2018 at 11:57 pm #80747Keep both and use them both π
August 7, 2018 at 12:20 am #80748Jim, I have been through this many times with my "parts" motors. I hate to see them not brought back to life, even if they have what seems to be slim chance. Yours is even running which is 90% of the battle!
I say go for it. Get them both going.
Just my 2 cents.
Bob DAugust 7, 2018 at 1:19 am #80754They both seem to run good, so I’d want to get both of them restored.
1959 Johnson QD-20βEvery 20 minute job is only a broken bolt away from a 3-day project.β
"Every time you remove a broken or seized bolt an angel gets his wings."August 7, 2018 at 9:45 am #80761You’d need a drive shaft, plus the bearings, for the ’76. The drive shaft will be hard to come by and/or expensive. I am not totally convinced that the ’76 will just bolt on the the ’69. Maybe, but I wouldn’t hold my breath. You really have to examine that stuff part by part, stud by stud. I have seen times where everything looks to be a "go," but two studs are out of place by an 1/8", etc, etc. There is a REASON Merc guys need a SERIAL number to order parts. If I were you, I’d be putting the ’69 on temporary hold and searching out an American built ’76ish lower unit with stainless shafts. Now THOSE are great motors!
