Home Forum Ask A Member dents in tanks
  • #284254
    Hiawatha
      has anyone had any luck pressurizing at thank to help pop out dents? thanks dave
      #284261
      JOSEPH BRINCAT
        Aluminum tank, yes?   It all depends on the nature of the dent. First, if there is any indication of a crease or kink forget trying. If the dent is a simple shallow belly, a lot can be done with air pressure, heat and light hammering around the perimeter of the dent. Go easy on the pressure, just few PSI, or you will turn that tank into a beach ball. Someone here likely has more info or even a video tutorial. If you had been a Constantine last summer, Jay put on a very good seminar and demonstration on just this thing.  ALSO,, the old Johnson service manual has instructions.
        #284265
        Hiawatha
          awesome!!! thanks going to give it a try
          #284268
            Square tank (mostly pre. WWII) or molded tank (after WWII)?
            Square tanks are easily braced so you can support areas that are
            not damaged while you work on a spot that is. The shape’s of
            post war tanks makes that difficult. Post war tanks are thinner
            and you can easily distort an area that isn’t damaged while
            attempting to repair a spot that is so pay attention to the whole
            tank as you apply air. Turning down the air at your compressor
            and having another regulator in line to the tank gives you good
            control so you can watch the tank as you increase the pressure.
            My experience is mostly with square tanks. My success using
            air is nothing to brag about but I keep trying. For me, the type
            of dent and its location determines how successful the end result
            will be. Some tanks will take 30 lbs.+ of air, while 3 or 4 lbs. puts
            you in the danger zone with others. There all kinds of videos on
            You Tube on removing gas tank dents using air.
            Might be something there you can use. If this is the only tank you
            have for the motor, just be careful!!!!
