Home › Forum › Ask A Member › Difference between a 48 & 50hp OMC?
- This topic has 11 replies, 9 voices, and was last updated 8 years, 9 months ago by
chinewalker.
July 25, 2016 at 9:31 pm #4840
Can someone tell me what makes this difference? Looking on M.E. at an ’87 model, and carbs appear the same with orifice plugs, and manifold appears the same too. Cylinder/crankcase even has the same P/N’s. Maybe I missed something here, exhaust housing manipulation?
July 25, 2016 at 10:12 pm #40933Burp in the Marketing department?
July 25, 2016 at 10:29 pm #4093448 had less glossy paint on some. Also no VRO also no power trim and tilt. A Marketing tool. OMC also made 28 and 88 basic motors also.
July 25, 2016 at 11:01 pm #40940Yes, the 48 and 50hps are really the same, same block, pistons, exhaust, carbs, manifold….This is just a marketing technique to differentiate the lower cost 48hp from the more expensive 50hp models…The 50hps had oil injection, and in some cases, a larger alternator…
July 25, 2016 at 11:18 pm #40942Anonymous
Clever! Make it obvious you’re a cheapskate!!
Did the "industrial" models also have "different" HP ratings at some point?
July 26, 2016 at 12:27 am #40953Often times the commercial models were resurrections of older models. Sometimes models with the fancy bells and whistles stripped off.
July 26, 2016 at 2:32 am #409592
😆Member of the MOB chapter.
I live in Northwest IndianaJuly 26, 2016 at 4:00 am #40961As I remember it "Special" models were introduced to give OMC dealers something to compete with Bagliner (Bayliner) dealers & Force motors. These were entry level buyers looking to get into boating as cheaply as possible. The 28, 48, 88, 112hp "Specials" we’re brought out by OMC as no frills models. As previously stated no VRO, no TNT, & on the V-4 the smallest alternator with no regulator. I don’t remember any paint difference (that would have just cost more), but the decals were sparse with a SPL designation. The 88 & 112 immediately got TNT kits offered to dealers along with the motors at a discount so you see a lot of them with trim. A 148 was considered, but never came to be. A lot of these motors were sold, especially in the V-4 range down my way. You still see them on the water today.
Dan in TN
July 26, 2016 at 6:23 am #40964I will say, I was surprised at how ‘clean’ the standard fuel pump and line set up was on this ’87 model 48hp motor was. Makes sense now. No VRO (not on the hood either), and just like the pre ’85 models of all variations.
July 26, 2016 at 4:12 pm #40977I could be wrong but I think somewhere in my travels I heard that the 48 spl, 88 spl and other special models used some older non thru hub lower units, as OMC had a stockpile of these NOS lower units, and wanted to use them up. I could be wrong, someone correct me if I am…
