Home Forum Ask A Member Do you use a spray in empty gas tanks?
  • #7786
    richardg
      I have found several motors with dusty corrosion inside the integral aluminum fuel tanks.
      Does anyone spray the inside of their fuel tanks with something like WD40 before storing the motor to prevent this?
      #62418
      RICHARD A. WHITE
        slosh some fuel in it, pour out the fuel…
        classicomctools@gmail.com
        #62424
        edgartc
          I pull the tank and plug the gas line connector, put some rec. gas in with a hand full of 1/4-20 nuts slosh it around and let is set a day or two slosh it whenever I walk past the usually clean up good
          #62427
            For long term storage I put in some straight TCW-III,
            and slosh it around. The most important thing is the
            tank is sealed up. If air can get in and out it brings
            moisture with it.
