Home › Forum › Ask A Member › Drive Shaft Repair
- This topic has 18 replies, 8 voices, and was last updated 7 years, 3 months ago by
George Emmanuel.
June 23, 2019 at 5:48 pm #177884
following
June 23, 2019 at 7:52 pm #177889I was wondering how successful it would be to “sleeve” the drive shaft seal area,
I’ve thought about that but haven’t tried it yet. The idea was to turn a stainless sleeve slightly larger than the diameter of the shaft and then weld it on. Then it could be finished to size in the lathe and keeping it true at the same time. The only issue then would be getting the bushing in the housing reamed/honed to fit as I’d have to send it out to a machine shop to get that done.
June 23, 2019 at 9:05 pm #177895Here’s a video (“for entertainment purposes only”!) of Garry Maffei trying a speedi-sleeve on a drive shaft. [if I can get the forum to NOT remove the link]: https://www.youtube.com/watch?v=Q6xghWrEmSU
http://www.omc-boats.org
http://www.aerocraft-boats.org-
This reply was modified 7 years, 3 months ago by
Phil Budne.
June 23, 2019 at 9:23 pm #177899Thanks Phil. His drive shaft is a lot nicer looking than mine, but looks like
it is indeed possible. Yes, it was very entertaining watching him
use the claw hammer, lol.Prepare to be boarded!
June 23, 2019 at 9:39 pm #177901Found a listing here for the sleeves……
https://www.globaloring.com/?s=SRS99062Amazon has them ……….
https://www.amazon.com/SKF-99062-Speedi-Sleeves/dp/B000EPOHQY/ref=cm_cr_arp_d_product_top?ie=UTF8Not exactly cheap at $27 plus…… especially if you ruin one.
June 24, 2019 at 7:22 pm #177918Investigate and see if there is another seal with slightly smaller i.d. You could then grind the shaft and problem solved.
George
June 24, 2019 at 8:20 pm #177921George, I don’t understand how that would work, being the seal is almost in the
middle of the drive shaft, unless the smaller seal would stretch over the drive shaft,
to the turned down area. Is that what you mean?
Thanks.Prepare to be boarded!
June 25, 2019 at 8:19 am #177939Buc,
That is what I though George was thinking. Just a slight difference, so it would stretch over.
David Bartlett
Pine Tree Boating Club Chapter"I don't fully understand everything I know!"
June 26, 2019 at 8:29 am #177991Yep that’s what I meant unless the pitting is so deep that a seal won’t work.
George Emmanuel.
