Home › Forum › Ask A Member › DVA Values For late 70’s Suzuki
- This topic has 6 replies, 2 voices, and was last updated 6 years, 8 months ago by
shane-r13.
September 21, 2018 at 3:32 pm #11293
Hi All,
Back again. I had posted earlier about a no spark issue on my 1978 Artic Spirit (Suzuki made). I have purchased a DVA adapter for my multimeter. I’ve obtained some values but don’t know what they should be. Ive read that it should be similar to a mercury value? In all honesty I’ve never had to diagnosis a CDI ignition before so i’m not sure what wires i should be test. Example trigger to trigger wire or one trigger wire to ground etc.
So far I have,
One trigger wire to ground – 188volts, the other trigger wire to ground – 177volts.
Charging coil to ground is 9.78Volts on one wire, other wire no reading.
CDI to igniton coil wire and ground – No reading.Just from an assumption seems like my CDI is bad, hence the no spark?
Any tips, pointers, advice is as always appreciated!
Thanks,
ShaneSeptember 21, 2018 at 3:48 pm #83318I may have that chart at home, lemme dig after work
classicomctools@gmail.comSeptember 21, 2018 at 7:02 pm #83326I’d appreciate that Richard.
Thanks,
ShaneSeptember 22, 2018 at 1:09 am #83337I am sorry I only have the following:
Chrysler
Force
Johnson
Mercury
and YamahaI did find this, so if Suzuki used one of these you are in business:
http://www.cdielectronics.com/wp-conten … Charts.pdf
Then I found this tid bit, I will copy:
daselbee
CommanderJoin Date: Jan 2009
#3
June 10th, 2012, 02:57 AM
Re: DVA Voltage specs neededThank you very much. I had no idea that Yamaha and Suzuki were the same….
Gives me something to do today!
And I hope this is what you need
classicomctools@gmail.comSeptember 22, 2018 at 1:23 am #83338Thanks Richard. Now to just decipher the colors and what wire is what between the two as i’m sure Yamaha used different colors than Suzuki. They wouldn’t want to make it easy or simple.
What are your thoughts on no voltage from the CDI unit?
Thanks,
ShaneSeptember 22, 2018 at 1:30 am #83339Honestly I have no clue, it was info I found a few years ago, and kept it, Not one single motor in my collection uses that kind of ignition… my faves are Battery Ignition RBM’s so I am not much help.
classicomctools@gmail.comSeptember 22, 2018 at 1:56 am #83341I wish it didn’t use this ignition as well. But its a great motor for what i use it for….when it ran.
