Home Forum Ask A Member Early Johnson Plunger for Pump
  • #251397
    davidk
      This is a water pump from a Johnson DN. The plunger is worn, but not all the way through. What’s the fix? Probably have to find another, maybe under a pile of hen’s teeth?
      As these plungers wear down, they must pump less water, right? I wonder if that’s why a prior owner put that “scoop” on there?
      IMG_6182
      IMG_6183
      IMG_6184
      #251410
        Even though the piston is worn its the cam that
        controls its stroke so piston wear doesn’t reduce
        the volume of water. Problems arise when a
        hole is worn through the piston. Depending
        on how much you plan on running it, its
        probably OK as it is. If you get to the point
        where you have a hole, the Buccaneer would
        just make a new piston. A boat house repair
        would be to file the piston flat, take a piece of
        thick wall copper tubing, cut it open, hammer
        it flat. Shape it to the size of the piston and
        solder it on, if I couldn’t find anyone to make
        me a new piston.
        A "Boat House Repair" is one that done without having tools or the skills to do it properly.
        #251437
        davidk
          Thanks for the reply, Tubs. I was thinking a shortened piston would pump less water. Not sure where I got that calculus?
          I appreciate your suggestion that it might be fine just to keep using it for as infrequently as I might run it.
          All kinds of mystical things can happen in that boat house!
          #251491
          PM T2
            I’d suggest that you at least go to the trouble of figuring out how thick the bottom of the plunger still is. Rudimentary measurement using the depth rod on a dial caliper would more than suffice. It might have sufficient material left, it might be paper thin. You at least want to know what you have.
            Hope it helps.
            Best,
            PM T2
            #251495
            davidk
              Thanks PM-T2, that’s a good suggestion and only requires
              rudimentary skills. : )
              • This reply was modified 3 years, 1 month ago by davidk.
              #251620
                On a couple pumps I squared off the end of the worn piston and silver soldered a flat piece of brass onto it. I thought about using a penny but copper might be too soft. The worn and damaged cams got reprofiled to and the thickness of the brass piece allowed for what was removed from the cam and the piston. The piston height and stroke remained the same as stock.
                DSC00672
                DSC00673
                DSC01521
                DSC01524
                #251651
                davidk
                  Nice work, Mumbles! I can see that it was essential to reprofile that cam or it would have been a grinder on the repaired plunger. Thanks for the photos and explanation.
                  -David
                  #251660
                  Monte NZ
                    International Member
                    Brilliant work Mumbles on that cam!……..the photos are excellent too…..well done!
                    Monte NZ
                    #252020
                    davidk
                      Here’s the cam from the DN. Looks corroded. Mumbles, I’m wondering how you were able to turn yours to clean it up when the cam is …..off center? I suppose it’s the shaft that’s off center, but, you probably get what I’m asking.
                      IMG_6222
                      IMG_6223
                      #252032
                        The gear is centred to the shaft but the lobe is off. This is where the four jaw chuck and a dial indicator are used to centre the axis of the lobe. If you don’t have a four jaw, one jaw in a three jaw chuck can be installed one turn of the scroll out of synch of the other two. This will give a rough non adjustable offset but shims can be placed under the teeth of two of the jaws to get a finer adjustment.
                        The prop shaft wasn’t threaded on either end so I used a rotating chuck in the tailstock to keep pressure on the cam while it was being turned. The piece of copper tubing in my last photo was used to get the clearance needed to get a good unobstructed cut.
