Home › Forum › Ask A Member › Elgin Fuel Leak
  • #1300
    emartin
      I recently acquired 1954 6hp Elgin. Much to my surprise it fired up after only a few pulls.
      While running in a barrel, fuel drips out under a cover/inspection ?? plate part # 562471 on the left side.
      Is this normal? I know some of these older motors had crankcase puddle drains that dripped right out in plain sight.
      Thanks
      #14554
      jim-moffatt
        The puddle drain cover is in front of the transfer port cover. It has an odd shape. If thats whats leaking remove it and reseal the gasket with sealer.
        #14601
        emartin
          That’s it…kind of L shaped with ears at the top
          Thanks for reply
