Home › Forum › Ask A Member › Elgin Outboard Impeller swap
  • #269302
      Just wanted to show a seemingly successful Elgin impeller
      swap, replacing the original 10 vane rubber impellers (one inch plus tall)
      with two Mercury impellers stacked together.
      Slight modifications were required, such as drilling the driveshaft
      for two impeller drive pins, to drive the Merc impellers.
      The original Elgin impeller was driven by the driveshaft splines.
      The driveshaft is “very” hard drilling by the way!
      Thanks to Brian Wilcox for “tips” on doing this conversion!
      My camera was aimed a little “low”, but it appears to be pumping water
      plenty good. How it will hold up will be the real test.
      https://youtu.be/Do6N6ho9gaY
      ALBERT MOORE
        buccaneer
        can you share the part number for the mercury impeller your using in the elgin outboard thanks AL
        al
        #269310
        CHUCK
          Some of those driveshafts are hardened steel.  Was it difficult to drill?
          #269311
            Buc – looks like it works great.   Glad it worked out!
            1982 Evinrude 25hp
            #269313
              buccaneer
              I used Mercury 47-89981 impellers.
              Sierra 18-3039
              They’re a little loose on the driveshaft, but I fit the
              drive pins tight to compensate.
                I spot drilled them with a machinist “center drill” on the milling machine,
                the switched to the size drill bit I wanted. I managed to drill the first
                hole to depth, about .200, but the drill wouldn’t touch the other
                hole, nor the other four bits I tried, lol.
                I ended up using the center drill to go to depth, which worked okay,
                but I had to use a larger diameter pin than I intended, which
                may have been better anyway.
                  You had mentioned that you also had ordered the Sierra equivalent of 47-89980. Did you end up feeling that they were too tight on the shaft?
                  #269316
                    Those ended up being “bigger”.
                    The 47-89981 I used had a center bore of .453
                    and the 47-89980 were .457.
                    Someone mentioned they had to bore the hubs ever so slightly
                    to fit over the driveshaft. Not sure what make or number those
                    impellers would have been.
                    All the impellers I got were Chinesium, so “fit” may not be as
                    good as the OEM impellers.
                    When I ordered the impellers, I ordered six all together, not
                    being sure if I was fixing two motors or one, or which impellers
                    would work out.
                      Including the pictures you posted in projects
                      might be helpful for others needing a substitute
                      for their Elgin.
                      #269340
                        for their Elgin.
                        Thanks for mentioning that Tubs.
                        Photos, including the impellers swap, in Current Projects…….
                        https://www.aomci.org/forums/topic/1951-elgin-7-5-hp/
