Home Forum Ask A Member Elgin Shear Pins
  • #4520
      I pulled the aluminum props off of three different little Elgin outboard (Westbend)
      and noted that they all had steel shear pins.
      Anyone have a chart saying if they’re suppose to be steel or brass?
      I did find one chart that listed the size as 5/32", but didn’t say what material.
      The prop on the 3.5 Elgin I was working on had a chunk out of the hub where
      the shear pin goes. Perhaps this was Sears’ plan to sell props?
      Also I ended up with a prop from a 2.5 Elgin. Tried one from a 5.5 hp,
      but too much pitch. Are these props and their pitch listed in any chart?
      Prop part numbers in this link…..
      viewtopic.php?f=2&t=7232&start=10
      on my last post.
      Thanks!
      RICHARD A. WHITE
        So what is the model number? OR look here see if it is in there…
        Regards
        Richard
        Thanks be to Garry in Tampa
        classicomctools@gmail.com
        #38432
        RICHARD A. WHITE
          By the way, to EVERYONE…ummm copy that picture to your computer, then you can have it as well 🙂
          Richard
          #38437
            I can look them up if you post the model numbers.
            #38447
              Richard, thanks for posting the shear pin chart. It tells me my
              Elgin takes a #5 Cosom shear pin, but is a #5 brass or steel I wonder?
              Frank, The model #’s of the Elgins are
              Model 571.58521 (3.5 hp)
              Model 571.58601 (5.5 hp)
              Model 571.58401 (2.5 hp)
              Thanks!
                All use same shear pin = 5/32" x 1-3/16" Brass
                571-58521 prop is 7-1/2" x 5-1/2"
                571-58601 prop is 7-1/2" x 7-1/2"
                571-58401 prop is 7-1/2" x 4-1/2"
                #38458
                  I would guess that the lack of a "*" after the pin dimensions on the first page above means brass
                  (the * means stainless)
                  #38467
                    Thanks all for the information.
                    I see now why the 3.5 Elgin was struggling with the 5.5 hp prop
                    on it. Just strange that all three I took
                    apart had steel shear pins.
                    rmhxruss
                      Does a chart exist with the original West Bend part numbers for these shear pins.
                      #38582
                      RICHARD A. WHITE
                        That chart is from the shear pin manufacturer, not sure if West Bend made a chart…
