Home › Forum › Ask A Member › Elto 1/2hp. Cub
Viewing 10 posts - 1 through 10 (of 21 total)
  • #292990
      Seems I posted this already.
      #292991
        And this also.
        #292992
          The coil seems to be good. More often they have failed. Found a leak though that might have cause a problem in damp weather. Took care of that when I replaced the plug wire.
          Video link –  https://youtu.be/QZS2AZeNINU
          #292993
          JOSEPH BRINCAT
            Creativity at work on the lock washer…. good idea. I’ll store that away for future reference
            Thanks
            #292994
              Working on the gas tank. Used Bob D’s suggestion to fill that deep dent with JB Weld. Used 2 different color primers for a future video to show how I get stuff straight. Those that are struggling with that may get something out of it. One more shot of primer and it “will” be ready for paint. I’ve had enough of it.
              #293000
              Monte NZ
                Comming along nicely Tubs……found the video interesting.
                Keep up the good work!
                Monte NZ
                #293044
                Shear Pin
                  What kind of tester is that?
                  #293091
                    I  would say a merc-o-tronic 88 .       98 possible but I don’t think so on the 98.
                    I may have a 98 for sale. 1 914 310 7086 Dave.
                    #293419
                      Its done. A good 10 footer. Be awhile before I can stick it a barrel to see if it will run. Going to the lake if does. Should look good in a video. Tubs
                      #293448
                      bob-d
                        Tubs, looks great, will this be one of your Maine motors? You must have been cranking. What did it take 3-4 weeks? Can’t wait to see the video of it running.
                        Bob D
