Home › Forum › Ask A Member › Elto ace flywheel removal
Does anyone have ideas for better removing a flywheel for the Elto ace? It doesn’t have the three tapped threads so common on other motors…. Thanks in advance,
Here’s a thread on the same subject that you might find useful:
viewtopic.php?f=2&t=1393&p=7415&hilit=hammer#p7415
Undo the nut and back off so just proud of the thread.
Being a wee motor wrap your arm around the flywheel only while holding the entire motor off the ground………BIG HUG.
A dead weight or shot filled hammer……………good whack on the nut.
"Pop"
It is off like swimwear at a Summer Camp Aye.
Remember to hit it with Intention………..no tapping tap tap will not do it.
So you have no spark?
B
Wow, thanks for the replies! I made a "flywheel smacker" and it worked!!
What a great idea!
Thanks from me as well!
