Home Forum Ask A Member Elto Cub info
  • #181640
    count
      I’m restoring a Cub and thought maybe someone could tell me a good starting point for the mixture needle. One full turn out? Two? Before I took it apart it was about five or six turns out, and it was flooding badly.
      #181676
      smokeonthewater
        By no means an official answer here, but I’ve generally used 1 turn on my small Elto’s to get me in the ballpark, when the original adjustment was found to be “somewhere in the weeds”
        #181701
        The Boat House
          count
            Thanks very much! Looks like 3/4 turn was just about right. However, I cannot get it to start in the water. I can start it on the stand then lift it and put it in the barrel. It dies immediately. Does it need new rings? Part number? Where can I get them?
            #181864
            The Boat House
              count
                Thanks, Tubs. I will get in touch with them. I have not taken the powerhead apart yet. Do you know the part number or size? Or maybe Otto knows the size…
                #181947
                  The usual problem is poor crankcase compression. The smaller the piston , the more sensitive it is too ware. A thousandth or two is hardy noticed on a big piston, but is a large amount as a percentage of size on a small one. Singles and alternate firing twins load the forward part of the main bearings which causes them to became egg shaped. This coupled with a lack of seals also causes a loss of pressure. The 2-½ horse Johnson is also sensitive in that respect. You can compensate somewhat by using a heavier oil. ie. SAE 40 or 60 weight. This would probably require a hotter heat range spark plug and will carbon over the exhaust ports. Some have knearled or stretched the piston skirt to increase sealing, but you don’t have much material to work with.
                  Garry in Michigan
                  #181952
                  The Boat House
