elto handitwin flywheel removal
Home Forum Ask A Member elto handitwin flywheel removal
  • Doug Wilson
    US Member - 2 Years
    Topics: 29
    #4017
    I am trying to remove the flywheel on an Elto Handitwin any suggestions? I have tried my normal fly wheel puller
    as well as using the rope shieve. It will not budge soaked it with PB blaster tried taping on it with dead blow hammer while flywheel puller was attached nothing seems to be working. The rest of the motor is in pretty clean and in good shape.
    Doug
    Doug
    turned off?
    ed-sam
    Topics: 1
    #34668
    Can you post a picture or suply a part number?
    Topics: 31
    #34675
    What is the model number? Here are some samples . . .
    1938
    Topics: 31
    #34676
    Using the rope sheave as a puller on a stubborn flywheel usually results in a broken rope sheave. A three screw flywheel puller with schedule eight bolts is the way to go. The factory puller uses shoulder bolts which ensures all are in at the same depth so the pull will be centered on the crankshaft but still will not go deep enough to damage the coil. I add a locking nut to my bolts to mimic the factory bolts
    There should be end play in the crankshaft. Lifting the flywheel should Allow the shock of the hammer blow loosen the flywheel without crushing the crankshaft. In extreme cases heat is used to expand the hub. It sounds like you are doing all the right things. It goes without saying that a gear puller which hooks to the outer edges of the flywheel should NEVER be used on a flywheel. All I can add is be patient . . . . . 😀
    Steve A W
    US Member - 2 Years
    Topics: 52
    #34680
    Here’s a link to Mr Tubs’ video on removing flywheel.
    https://www.youtube.com/watch?v=RWgE9XiIBnk
    Good Luck.
    Steve A W
    Member of the MOB chapter.
    I live in Northwest Indiana
    Doug Wilson
    US Member - 2 Years
    Topics: 29
    #34716
    model number is 4357 when i saw how tight it was changed to gear puller with trhee bolts letting pb blaster soak on it will try again tomorrow in the mean time cleaning the carb willhave it at the mob meett at lake freeman sat. on display
    Doug
    turned off?
    The Boat House
    Topics: 111
    #34727
    • This reply was modified 5 years, 5 months ago by The Boat House.
    • This reply was modified 3 years, 1 month ago by The Boat House.
    Doug Wilson
    US Member - 2 Years
    Topics: 29
    #34728
    the 3 bolt puller is what I am calling the gear puller would never use the jaws on the outside and risk trashing the fly wheel. Will try again tonight
    Doug
    turned off?
    eviltwin
    Topics: 5
    #34735
    Hi DD, I removed mine last summer. I removed the three screws that hold the rope sheve and got it out of the way.
    Mine is held down by a flat sided nut (not sure if that is OEM) so took that off with crescent wrench. I bought a
    3 hole puller at Harbor Freight and used it. Not sure if two nut method mentioned would have worked, try that
    first maybe. Here is a related post on my removal &point settings to save me typing: https://aomci.org/forum/viewtopic.php?f=2&t=3278&p=17157#p17157
    Some good info in there from members. Couple things to pass from my experience.
    1. If it is on tight, there probably is risk of damage, no matter how correctly you do it. Be prepared for that.
    2. WATCH OUT FOR THE COIL when threading bolts for puller. Mark your threads so they are in enough to hold
    but don’t go any deeper. They need to be threaded evenly anyway to center the puller so mark them. I was careless
    and heard a little crunch when I threaded one in and realized it had contacted the paper wrapper around the coil.
    Fortunately I stopped and no damage was done.
    3.Do Not use never seize on shaft to make it easier next time. In link above mumbles informs that it is too slippery
    and will actually shear the key off.
    4.Take your time and be careful, but firm. Clamp the motor to something stable, I used a wooden guardrail (lol!).
    Good luck, post pics when done. I am curious if yours looks like mine did inside.
    [Edit] added pic of it
