Home Forum Ask A Member ELTO rudder twin timer help
  • This topic has 12 replies, 2 voices, and was last updated 3 years ago by Tubs.
  • #258424
      I put the motor back together and back in its hole.
      You can get the bore sizes from your flywheel and timer.
      #258428
      joecb
        I understand that the center-to-center dimension is critical to correct timing. I did some more research and found that there was an article in a past issue of the “Outboarder” about this part. Trying to track down the July 1988 issue, page 13
        #258455
          Joe – Sent you a PM.
          Check you messages. Hurry.
