Home › Forum › Ask A Member › elto ruddertwin timing
- This topic has 7 replies, 4 voices, and was last updated 6 years, 10 months ago by
muddog2.
November 16, 2019 at 2:54 pm #187285
I took the cover off the timing and when I turn the shaft around I hear the click, but I don’t see the points move to contact the springs. Here are some pictures.
November 16, 2019 at 2:59 pm #187290I took the gas tank off, coil, timer, flywheel, to do some cleaning. Here are some pictures.
November 16, 2019 at 3:03 pm #187295Some more pictures
November 16, 2019 at 3:23 pm #187300I know the rod on the left that pulls up is to release pressure from exhaust when starting. The know on the bottom of carb is to adjust flow, What is the bar on the top for?
Here are some pictures of coil and wires. I am going to try to use as is at first. I saw a video on how to use the case on this coil and put a new coil inside and wires. Looks like something I would be able t do.November 16, 2019 at 5:16 pm #187312The points don’t close in the traditional manner. The hammer click is the sound of the points closing. It only lasts for fractions of a second.
The rod on top of the carb limits the height of the poppet valve. You adjust it for best operation when running.
Wayne
November 16, 2019 at 5:31 pm #187313The Atwater-Kent ignition system uses a spring loaded hammer to trigger the points to close. It happens so fast that you cannot see it with the naked eye. If you put on some magnifying glasses and look closely, you can glimpse a view of the action. The points are set at .009 inches and the only way to do any adjusting is to add or subtract the shims that are on the point end, with the screw. You should be able to see the shims there. Do NOT bend the long arm of the points. Usually the contacts just need a good cleaning. The Atwater-Kent is a good system and produces a great spark.
Rick
November 16, 2019 at 10:06 pm #187317November 17, 2019 at 12:42 pm #187355Thanks for the information.
Robert -
