Home › Forum › Ask A Member › Elto Speedster Model Numbers
- This topic has 14 replies, 5 voices, and was last updated 7 years, 10 months ago by
bill-loveland.
May 20, 2018 at 8:40 pm #9986
According to the article, Elto made the Speedster in three different
horse powers. My Speedster has the 310 number on it, so I’m
told it’s a 1930 Senior Speedster, 14 hp.
In looking at the Evinrude model number list, I don’t see
any 8 or 12 HP motors listed.
What would be the model numbers for these, and one
with the "Hi-Speed" option?Standard Speedster –
Model # –
B x S – 2-1/2" x 2"
8 HPSpecial Speedster
Model #-
Larger B x S
HP – 12 ?Senior Speedster
Model # 310
Extra heavy duty construction
Standard under water silencer
HP – 14Hi-Speed Option Speedster
"lighter construction"Prepare to be boarded!
May 20, 2018 at 10:07 pm #764351928 service speedster
model 355 – s/n 60000-699991929
model 300 and 301 – s/n 80000-89999
model 318 and 331 – service speedster with rudder
model 319, 320, 346 – service speedster with underwater exhaust
model 340 and 341 – Special Speedster
model 302 and 303 – Hi-Speed Speedster
model 333 – Hi-Speed Speedster with underwater exhaust1930
model 348 – Hi-Speed Service Speedster
Model 310 and 312 – Sr Speedster with battery ignition
model 311 and 313 – Sr Speedster electric1931
model 905, 906, 907 – Special Speedster
model 311 and 313 – Sr Speedster electric1932
model 311 and 313 – Sr Speedster electric1933
Model 361 and 363 – Sr Speedster with cord start
model 362 and 364 – Sr Speedster with knob start1934
model 365, 366 – Senior SpeedsterThat’s all I got. Taken out of the Evinrude-Elto model year guide. Hope it helps.
Where more than one model number for a given year – higher number usually 5 inches longer
Best,
May 20, 2018 at 10:23 pm #76437PM T2, Thanks for all that data. Much appreciated.
Interesting, but I see no mention of the Standard Speedster.
I’m not sure what the "Evinrude-Elto model year guide"
is exactly, but is it floating around the internet?
Thanks
Update – just learned in "Old Outboard Book" that
the Service and Standard speedster are one in the same, and
In 1929 the Standard / Service Speedster was 7 hp. It was "upped" to 8 hp in 1931
Also, that the High-Speed Speedsters had aluminum pistons, Auxillary air intakes, etc.Prepare to be boarded!
May 20, 2018 at 10:53 pm #76443Most of that information (but not all) is contained in the model-year guide that appears in Peter Hunn’s "The Old Outboard Book".
The missing parts are found in what I consider to be one of the best model-year guide booklets I’ve ever found. It was printed as "Outboard Motor Model & Serial No. Guide Prior to 1960". It was compiled by the Maple Leaf Chapter of the AOMCI back in the 1990’s.
This goes up to 1940, there’s more that goes to 1959 but this is the important part….
PM T2
May 20, 2018 at 11:09 pm #76445I have the Maple Leaf Chapter model year guide. It has the same ELTO Lightwin Model C serial number mistake as the Peter Hunn book. I’ve always wondered where the mistake originated. The Maple Leaf model guide is excellent because it includes the Canadian serial numbers, as well.
Wayne
May 21, 2018 at 12:36 am #76456Thanks again guys for the info.
Interesting enough, none of the data shows the
Standard Speedster hp being "upped" to 8 hp in 1931,
as PM T2’s article mentioned.Prepare to be boarded!
May 21, 2018 at 3:07 am #76462If you read carefully, you will find (or not find, in this case) that the Service Speedster doesn’t actually show up in the model-year guide for 1931.
All service Speedsters are recognized as 7 HP motors, so where the 8 HP rating comes from, I have no clue. Could be that there were plans in t he works for such an animal, but it never actually happened.
It was listed in the catalog as part of the Speedster family, but doesn’t show up in the model-year list. Where did it go, eh?
The 8 HP motor that did show up in 1932 was the Service "A", which should not be confoozed with the Service Speedster.
Best,
May 21, 2018 at 11:43 am #76468quote PM T2:If you read carefully, you will find (or not find, in this case) that the Service Speedster doesn’t actually show up in the model-year guide for 1931.All service Speedsters are recognized as 7 HP motors, so where the 8 HP rating comes from, I have no clue. Could be that there were plans in t he works for such an animal, but it never actually happened.
The 8 HP motor that did show up in 1932 was the Service “A”, which should not be confoozed with the Service Speedster.
Best,
PM T2I never seen a date in that article, but I was also thinking that it was
a possibility that they were touting something that never came to
fruition.
I was wondering about that "Service A" in 1932, but haven’t looked
for a photo of one yet.
All interesting!Prepare to be boarded!
May 21, 2018 at 1:11 pm #76476May 21, 2018 at 2:01 pm #76481They must not have known about the "Great Depression".
Life looked good…… electric start, and remote steering.
Wonder how the throttle was hooked up……. then again,
I don’t remember seeing anything but a couple of poppet
valves when I took the carb off……. will have to look again!Prepare to be boarded!
